Hi NoJo,
I’m an engineer at Teknic, and I saw your post. In case it wasn’t already mentioned, you can use ClearPath’s “Precision Homing” feature in conjunction with the “User Seeks Home” option to allow your controller to control the homing instead of allowing ClearPath to home autonomously. The autonomous homing is a nice feature for many types of machines, but most CNC controllers will “expect” to handle the homing process, so you may find the User Seeks Home option easier to code for.
(In the context of this post, I will be talking about the ClearPath-SD series which takes step and direction input. Unfortunately I don’t know much about your specific controller, so my advice is for a generic step and direction host controller, but I think it should apply here.)
To reiterate, there are two “homing styles” in the ClearPath-SD series: “Automatic” and “User Seeks Home”. Both options use Teknic’s hardstop homing algorithm (which finds a home reference position without the need for a home sensor and associated wiring).
The Automatic mode will initiate homing (and begin to move) as soon as you enable the servo, which is convenient for many types of machines, but the homing parameters (e.g., velocity and acceleration) are set within ClearPath and thus not under control of the host. Also, the host can only control the start of the homing sequence by enabling the motor, i.e., you can’t enable the motor and then later choose to home (without first toggling the Enable line).
The User Seeks Home style offers you more control over the homing process while still taking advantage of ClearPath’s hardstop homing feature. In this homing style, when you enable the motor, the hardstop detection algorithm becomes active (waiting to detect a hardstop, and limiting the torque to a lower torque limit, if desired), but no motion will occur without a command from the host.
When the host is ready to home, it sends the motor toward the hardstop (using the step and direction signals) while looking for ClearPath to assert the HLFB signal. When HLFB is asserted (meaning that ClearPath has detected the hardstop and moved to the offset position as set within ClearPath by the user), the user sends one or more steps in the direction away from the hardstop to “confirm” that it has seen HLFB assert. This turns off hardstop detection and restores the normal torque limit.
If you want to cancel homing for some reason (e.g., you already know where the axis is), sending one (or more) steps in each direction will cancel homing (i.e., turn off the hardstop detection and the homing torque limit). This also means you can jog the axis in one direction before beginning your homing sequence. (Jogging in both directions would deactivate the hardstop detection.) You can reactivate the hardstop detection by toggling the Enable line assuming you’ve set up ClearPath to home on every enable (as opposed to only homing on the first Enable after power-up).
So, with a generic step and direction controller, you can use the User Seeks Home style to have full control over your homing requirements. If you have firmware version 2.0 (which it sounds like you do), you can also use Precision Homing which allows for very accurate homing even if the hardstop changes a bit over time or temperature. Here is a video clip (start at 3:34) that explains Precision Homing (it’s in a video about the MC-series, so don’t get confused; it works the same in the SD-series):
Please feel free to contact Teknic at support@teknic.com or call us at 585-784-7454.
Best regards,
Trent T. – Teknic Servo Systems Engineer
