- Thank you received: 338
viesturs.lacis wrote:
tommylight wrote: Vhat VFD? Any schematics ?
I meant that Commander VFD in Biesse machines. Nevermind, I managed to find the manual: www.acontrol.com.pl/uploads/pdf/instrukc...er-CD-user-guide.pdf
tommylight wrote: Check the hal file and make sure the right encoder is using the right PWM.
When it jumps, does it trigger a disable ?
bevins wrote: I would suspect your pwm stuff before the analog out to be the issue. I don't know, never used that card.
Todd Zuercher wrote: Can you describe the mechanics of the Y-axis? Is the feedback encoder mounted directly to the Y motor or is it mounted to a ball-screw or is it a linear feedback device?
Todd Zuercher wrote: Tuning FF2 can be very touchy. Your plot shows you were using an FF2=0.000002. What happens with FF2=0.000003 or 0.0000025
