- Thank you received: 1480
Forum Header
Mach3 XML and Stepconfig issues.
9 years 6 months ago #91984
Replied by Todd Zuercher on topic Mach3 Xhttps://forum.linuxcnc.org/16-stepconf-wizard/32ML and Stepconfig issues.
Is is still pulsing using the type-2 stepgen and the phase-a signal?
9 years 6 months ago #91985
You'd also need to change this pin
net spindle-cw <= stepgen.2.step
to
net spindle-cw <= stepgen.2.phase-A
to
9 years 6 months ago #91986
by tecno
Replied by tecno on topic Mach3 Xhttps://forum.linuxcnc.org/16-stepconf-wizard/32ML and Stepconfig issues.
All settings as per your recommendations I can start spindle, Andy's phase = nothing as I have to edit out several lines to get LCNC started.
9 years 6 months ago #91987
You should only need to change 3 lines
loadrt stepgen step_type=0,0,1 ctrl_type=p,p,v
net spindle-ccw <= stepgen.2.dir
to
loadrt stepgen step_type=0,0,2 ctrl_type=p,p,v
net spindle-ccw <= motion.spindle-reverse
to
9 years 6 months ago #91988
by tecno
Will go down and test that, thanks Todd.
9 years 6 months ago #91989
oh, and comment out these 3
#setp stepgen.2.steplen 250000
#setp stepgen.2.stepspace 250000
#setp stepgen.2.dirdelay 35000
Time to create page: 0.173 seconds
