Forum Header
Mach3 XML and Stepconfig issues.
9 years 6 months ago #91950 by tecno
OK in Mach3 ( some occurrence of very long steps of shifting rpm's with maybe 20-30rpm is what I notice sometime.)
Will go down now and send latest hal if I get my network to work again. Also will have a picture of halscope.
9 years 6 months ago #91953 by tecno
File Name: Blomqvist_...4-24.hal
File Size:3.54 KB
9 years 6 months ago #91955 by tecno
Halscope
9 years 6 months ago #91958 by Todd Zuercher
May I suggest you start a new topic in the HAL section of the forum asking the question "Why is Stepgen not outputting a steady stream of pulses with a constant velocity command?"
You might get more answers there.
What were your Latency test results like on that PC?
9 years 6 months ago #91960 by tecno
9 years 6 months ago #91963 by Todd Zuercher
That doesn't seem too bad, if it was for a long enough duration of time, with a sufficient load on the system.
Could you try running the Latency Histogram, from the apps section of the config picker.
I am kind of baffled.
Time to create page: 0.105 seconds
