Remora - NVEM / EC300 / EC500
- rbobey1989
- Thank you received: 30
14 Feb 2023 21:49 - 14 Feb 2023 22:00 #264527
by rbobey1989
Replied by rbobey1989 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
hello everyone, I have continued doing tests and the power supply of the MAX3232 is 3.3V which remains fixed without connecting the I/O power supply, it goes with the board's power supply, for which I ask the following question in the forum I ask the Keep asking everyone around here:
Someone has connected the RS232 output (RXD TXD and GND) in a physical COM port DB9 connector, Scott could you tell me which is the USB-RS232 converter that you use in the video where you show the configuration of the board, I have an oscilloscope at work for what I will use it to see the waveform on the rs232 side, although that will have to wait until Monday because I don't get the stlinks, thanks to all
Last edit: 14 Feb 2023 22:00 by rbobey1989.
- scotta
- Thank you received: 480
14 Feb 2023 21:55 #264528
by scotta
- Domi
15 Feb 2023 08:31 #264552
by Domi
Replied by Domi on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello. The signal from 0-10V takes about 13 seconds. Is it possible to use pwm-gen to increase the frequency? Can you advise how to set up the hall? I tried it but it doesn't work. I don't know how to continue and to which pin to connect the pwm-gen. Well thank you
linuxcnc.org/docs/html/man/man9/pwmgen.9.html
- scotta
16 Feb 2023 01:19 - 16 Feb 2023 01:20 #264592
by scotta
Sounds like you have an earlier NVEM which has the op amp type analogue output. I think some Mach3 users have changes the capacitor to improve the responsiveness.
www.cnczone.com/forums/controller-cards/...638.html#post2436638
Also, you will not be able to use the pwmgen component as it needs to run in a base thread.
Last edit: 16 Feb 2023 01:20 by scotta.
- Domi
16 Feb 2023 08:05 #264602
by Domi
Thank you very much. I also used 1uF. Now it's about 0.5 seconds from 0-10V.
- AlessandroEmm
17 Feb 2023 19:07 #264715
by AlessandroEmm
Replied by AlessandroEmm on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hey there,
sorry if i missed it, would anyone have the pinout for the Headers of the NVEM Board (on the underside) with the later RT1052 MCU?. Unfortunately those dont have any marking on the pinout.
Thanks!
Alessandro
Thanks!
Alessandro
- scotta
17 Feb 2023 20:08 #264719
by scotta
forum.linuxcnc.org/18-computer/44828-rem...ard?start=470#252585
You can find it hereHey there,
Thanks!
Alessandro
- AlessandroEmm
18 Feb 2023 06:20 #264739
by AlessandroEmm
Thanks Scott, but thats for the EC300 I understand? Would the NVEM use the same order of pinout?
- dec0077
21 Feb 2023 21:17 #264984
by dec0077
Replied by dec0077 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I finally got my oscilloscope today and put it to work right away.
This first image is what I get out of the optocoupler; Voltage goes from -10V to +8V and the wave is all but square... the less said about the duty cycle, the better.
This second one is the output on VSO (sorry for the quality, it was difficult to take a picture while holding the probe to one of the pins); again goes both positive and negative, is about 250mV p-p and does not approximate a ramp in any way, shape or form.
Given these waveforms, I think I'll not be able to drive the spindle directly, it's almost as if the PWM section of my board is faulty.
What do you think?
Best Regards,
Alberto
What do you think?
Best Regards,
Alberto
- rbobey1989
23 Feb 2023 01:46 #265083
by rbobey1989
Hi Scott, I've been testing with remora-rt1052 for a couple of days and there has been progress, as I mentioned before I managed to fake remora-rt1052.bin without problems, I installed the remora-nv component, I ping the board without problems, LinuxCnC Exits E-Stop as expected, homing ok, Gcode execution starts, but I get !!!!following errors!!!!! sporadic in LinuxCnC, I have tried lowering the speedups, changing the FERROR and MIN_FERROR and I have not had any luck, I have taken as first reference the sample configuration of remora-nvem-basic and the remora-nv component from Scott's repository for a clean configuration to perform tests.
github.com/scottalford75/Remora-NVEM/tree/main/LinuxCNC
I can't think of anything else to try if you have an idea of course it will be well received.
I am going to prepare LinuxCnC in RPI4 to test since right now I am on a computer with debian 12 but enough for today 2:37 am, exhausted. ideas please......
Time to create page: 0.266 seconds
