Remora - NVEM / EC300 / EC500
23 Feb 2023 21:58 #265157 by dec0077
In the end, I gave up on trying to drive the spindle via the NVEM card and went with Scott's suggestion of using an USB-to-RS485 adapter to drive the Huanyang VFD.
It's not my preferred solution (otherwise I wouldn't have gone with a NVEM in the first place), but at least it works, and the RPMs i get are surprisingly precise, within 2rpm of the requested value.
Now I have to handle homing and the probe, but those shouldn't be difficult to get right.
Best Regards,
Alberto M.
26 Feb 2023 10:21 - 27 Feb 2023 09:00 #265403 by andrewt12
Replied by andrewt12 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi All,
Im having issues configuring the new NVEM v4 with RT1052. I have the steppers working but cant get any of the IO to work.
If I use remora.output.3 or remora.input.3 within my HAL file the inputs and outputs do not toggle. I did have it working when using STM32 EC500 device.
Am I using the wrong syntax for the IO and should the IO numbers match what is printed on the case?
Any help would be appreciated.
Edit 27/2
Never mind, figured out the IO, but am struggling to get the encoder on the MPG working. Any tips?
Last edit: 27 Feb 2023 09:00 by andrewt12. Reason: Figured it out.
  • scotta
  • Platinum Member
  • Platinum Member
27 Feb 2023 21:18 #265518 by scotta
If you can see the encoder inputs flicker in the watch window in "Show HAL Configuration", then it is a setup / configuration.
I do seem to remember that I could only jog with the MPG after jogging with the keyboard first. Machine needs to be homed as well.
28 Feb 2023 06:34 - 28 Feb 2023 09:46 #265532 by andrewt12
are these the correct inputs for rt1052 nvem?
net mpg-a encoder.0.phase-A <= remora.input.28
net mpg-b encoder.0.phase-B <= remora.input.27
I cant see where in the code the mpg encoder is  being read.
Thank you for your help and your hard work putting this together.
Cheers
Last edit: 28 Feb 2023 09:46 by andrewt12.
28 Feb 2023 11:50 #265554 by Domi
Hello. Anyone using INDEX Input on nvem v2? I have connected 0-5V from vfd to INDEX input nvem. Speed is not shown on the display. Something needs to be changed in HAL. ? Well thank you
  • scotta
  • Platinum Member
  • Platinum Member
28 Feb 2023 20:37 #265607 by scotta
Thanks Scott, but thats for the EC300 I understand? Would the NVEM use the same order of pinout?
Sorry, RT1052 based NVEM pinout is as below.
The following user(s) said Thank You: AlessandroEmm
  • scotta
  • Platinum Member
  • Platinum Member
28 Feb 2023 20:49 #265610 by scotta
Cheers
I've just had another look at the RT1052 code and looks to be an issue with the encoder inputs. I'll put the EC300/NVEM back on the bench to test.
  • scotta
  • Platinum Member
  • Platinum Member
28 Feb 2023 20:54 #265612 by scotta
The INDEX input is a digital input, normally connected to a spindle sensor. In LinuxCNC the HAL would need to be set-up appropriately as well.
  • scotta
  • Platinum Member
  • Platinum Member
01 Mar 2023 06:07 #265635 by scotta
Cheers
I've just done a bug fix, pushing version 0.0.1 to the Develop branch. I've got NVMPG jogging working on the bench.
github.com/scottalford75/Remora-RT1052/b...ora-rt1052-0.0.1.bin
The following user(s) said Thank You: andrewt12
01 Mar 2023 08:08 #265638 by AlessandroEmm
Replied by AlessandroEmm on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Thanks a lot Scott!
Time to create page: 0.262 seconds
