Remora - NVEM / EC300 / EC500
- vpomerleau
- Thank you received: 3
Murphy wrote:
This is great work. Currently doing a Denford mill retrofit with parallel cards. I also have an emco little CNC waiting to get converted. Is it possible to get these to work with encoder inputs? Ie a toolchanger?.
I'll also add Encode and QEI features to the list.
NVEM has two available QEI interfaces available for high speed counting on FHA + FHB and INP7 + INP8.
EC500 has three available QEI interfaces available for high speed counting on IN5 + IN6, IN9 + IN10 and IN12 + IN13. One of these is on TIMER1 so I'll setup the DMA step generation on TIMER8.
For a tool changer software encoder support should be more than adequate.
First your work is awesome Scott, I think there's really much support here than from the company. Do you think one of these input can handle the index pulse for the spindle PID on the EC500, I saw the V5 have a pin for this and but mine is older. I'm currently on mach3 but I really thinking about taking the big dive for linuxcnc!
- REX299
- Visitor
- andrewt12
I remember seeing a way of funding you for your efforts but I can not find it. Can you please share a link.
Cheers
- scotta
- Thank you received: 480
Great to hear. GoFundMe is still running.Thanks Scotta. I am a happy camper.
Cheers
www.gofundme.com/f/remora-firmware-devel...gn=p_cf+share-flow-1
- scotta
Hi, can you explain a little more? What in particular is not working. Inputs, encoder? What is your HAL setup?I am using standard MPG and it not working with Remora, What does I need to do if it can work with Standard MPG? Thanks?
- zmrdko
- Thank you received: 49
first of all, nice work @scotta.
Im trying to flash ec500 (IMXR_EC500 2022-09-07), but I am unable to compile the files.
The direct flash for the first time does not work as I read in this thread.
I have probe visible in MCU Expresso but I have issue with lwip folder and I get about 40errors:
Description Resource Path Location Type
'ERR_OK' undeclared (first use in this function) NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 40 C/C++ Problem
'ERR_OK' undeclared (first use in this function) NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 62 C/C++ Problem
'ERR_OK' undeclared (first use in this function) NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 111 C/C++ Problem
'eth_data_count' undeclared (first use in this function) NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 7 C/C++ Problem
'eth_data' undeclared (first use in this function) NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 11 C/C++ Problem
'ETH_HWADDR_LEN' undeclared (first use in this function) NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 59 C/C++ Problem
'etharp_output' undeclared (first use in this function) NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 53 C/C++ Problem
'ETHERNET_MTU' undeclared (first use in this function) NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 55 C/C++ Problem
'ethip6_output' undeclared (first use in this function); did you mean 'netif_output'? NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 54 C/C++ Problem
'ifinnucastpkts' undeclared (first use in this function) NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 108 C/C++ Problem
'ifinoctets' undeclared (first use in this function) NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 103 C/C++ Problem
'ifinucastpkts' undeclared (first use in this function) NO_SYS_SampleCode.c /remora-rt1052/lwip/doc line 106 C/C++ Problem
I have installed SDK_2.x_MIMXRT1052xxxxB_EA. version 2.8.6.
MCU is set to chip: MIMXRT1052xxxxB
Am I missing any library or something?
- zmrdko
- frayja2002
- Thank you received: 12
A bit of a noob question.
I'm using the example remora-nvem.hal file
I have connected my estop switch to pin 20 of my NVEM board IE remora.input.20 but when I point this to iocontrol.0.emc-enable-in it gives me an error saying its already in use, which it is in this line
net user-enable-out <= iocontrol.0.user-enable-out => remora.enable
So what would be the correct way to set this up while not breaking something else.
Alex
- scotta
- frayja2002
Apart from using the parallel port wizard, I have never really played with the HAL file.
Any insights into how it all glues together would be good.
Alex
