7i96 Configuration Tool Deb
5 years 9 months ago #196457 by BigJohnT
I've added stepgens, encoders and pwms by firmware selected and if a pwm is present enabled the spindle pwm.
Current version is 1.2.4
github.com/jethornton/7i96
file:///home/john/github/7i96/docs/build/html/index.html
Note: it might take a bit for Travis to update the docs.
JT
5 years 9 months ago #197154 by BigJohnT
I just pushed a new deb with a couple of fixes and a better check for mesaflash and the correct version of python.
JT
The following user(s) said Thank You: RotarySMP, persei8
5 years 7 months ago #202002 by mattl
Replied by mattl on topic 7i96 Configuration Tool Deb
Thanks for making this tool, it's been a great help for me!
I noticed that your new version doesn't include any parallel port information in it. Was that by design?
5 years 7 months ago #202211 by BigJohnT
mattl wrote: Thanks for making this tool, it's been a great help for me!
I'm not sure what you mean, IIRC the 7i96 Configuration tool has never shown parallel port information.
JT
5 years 7 months ago #202213 by BigJohnT
I've added menu items to get a list of pins, parameters and signals and save them in the configuration directory. Makes editing the hal files easier when you can copy and past pins and parameters. I'm also reworking the deb at the moment and should have all this uploaded today. The new version is 1.2.5.
JT
5 years 7 months ago - 5 years 7 months ago #202340 by BigJohnT
I just finished adding the input invert code.
Fixed
[strike]Edit: I have a small error right now and it doesn't load the invert or normal when you open an ini...
[/strike]
JT
Last edit: 5 years 7 months ago by BigJohnT.
The following user(s) said Thank You: Markyd
Moderators: PCW, jmelson
Time to create page: 0.059 seconds
