- Thank you received: 994
7i96 Configuration Tool Deb
5 years 6 months ago #206185
by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool Deb
Well the Smart Serial section now properly loads from the ini file so now it'd done... I think.
JT
JT
5 years 6 months ago #206788
by BigJohnT
I've been working on a much better way to select input connections and tossed out the combobox in favor of a pushbutton with a menu attached to it. Now you can drill down a list by category and select what you want. It was quite interesting to figure it all out without using a billion lines of code. The code to build the inputs hal file is now just a few lines long so much easier to trouble shoot.
JT
JT
- restinpeace
5 years 6 months ago #206939
by restinpeace
Replied by restinpeace on topic 7i96 Configuration Tool Deb
i try to install with following command "sudo apt install 7i76e_1.0.2_all.deb" the Config Tool but i got no luck.
i get this Error Msg :
Couldn't find any package by glob '7i76e_1.0.2_all.deb'
> E: Couldn't find any package by regex '7i76e_1.0.2_all.deb'
so whats wrong with this deb file. im using this debian from the linuxcnc Website .
any Help welcomed. thx. Dennis
5 years 6 months ago - 5 years 6 months ago #206966
by MartynT
Replied by MartynT on topic 7i96 and 7i76e Configuration Tools
Hi John,
Many thanks for this - it looks like it could help me. New to LinuxCNC but have run Debian systems for years.
I tried to install the latest version (1.3.0) from Github but encountered some issues so I created an issue report:
"Lintian check failed with the following issues:
E: 7i96: description-starts-with-package-name
W: 7i96: desktop-entry-lacks-main-category usr/share/applications/7i96 Configurator.desktop
Lintian finished with exit status 1
Installing in terminal with dpkg installs OK but application in the CNC folder is named "Something". When opened shows title as version 1.2.6"
Last edit: 5 years 6 months ago by MartynT. Reason: Typo
5 years 6 months ago #207000
by BigJohnT
Replied by BigJohnT on topic 7i96 and 7i76e Configuration Tools
The current version of the 7i96 Configuration Tool is 1.3.0.
JT
JT
5 years 6 months ago #207001
by BigJohnT
My configuration tools are not in the Debian repo, you must follow the instructions in the install page and use Gdebi to install from the deb file.
JT
JT
Time to create page: 0.064 seconds
