- Thank you received: 994
7i96 Configuration Tool Deb
5 years 9 months ago #195212
by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool Deb
On the PLC tab you can change the defaults for Classicladder.
image missing https://raw.githubusercontent.com/jethornton/7i96/master/screenshots/7i96-PLC.png
JT
JT
5 years 9 months ago #195214
by BigJohnT
On the Options tab you can select various options.
image missing https://raw.githubusercontent.com/jethornton/7i96/master/screenshots/7i96-Options.png
JT
JT
5 years 9 months ago #195215
by BigJohnT
On the Outputs tab you can configure the outputs of course.
image missing https://raw.githubusercontent.com/jethornton/7i96/master/screenshots/7i96-Outputs.png
JT
JT
5 years 9 months ago #195216
by BigJohnT
On the Inputs tab you can configure the inputs
image missing https://raw.githubusercontent.com/jethornton/7i96/master/screenshots/7i96-Inputs.png
JT
JT
5 years 9 months ago #195217
by BigJohnT
On the spindle tab you can configure all 4 types of PWM spindle types.
image missing https://raw.githubusercontent.com/jethornton/7i96/master/screenshots/7i96-Spindle.png
JT
JT
5 years 9 months ago #195314
by BigJohnT
Also I'd like to point out that you can configure any combination of axes with this tool, there are no preset machine types you have to use. So if you have an X U A configuration this tool will make that for you. If you just have a Z axis the tool will make a single axis configuration for you.
JT
JT
Time to create page: 0.390 seconds
