ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
  • ALittleOffTheRails
  • New Member
  • New Member
4 years 8 months ago #235834 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Using Xubuntu 21.04 (Litex installed)
root@E555:/temp/colorcnc# ./colorlight_5a_75b.py Traceback (most recent call last):   File "/temp/colorcnc/./colorlight_5a_75b.py", line 15, in <module>     from litex_boards.platforms import colorlight_5a_75b ModuleNotFoundError: No module named 'litex_boards' I have no idea why.
First of all running as root is a really bad idea.
Have you installed the Litex packages and the oss_cad_suite ?
4 years 8 months ago #235908 by tuxcnc
Why ?
Many peoples tell me "it is bad idea", but nobody can tell why ...
4 years 8 months ago - 4 years 8 months ago #235909 by tuxcnc
Obsolete content. Deleted.
Last edit: 4 years 8 months ago by tuxcnc.
4 years 8 months ago #235915 by tommylight
Why ?
Linux is not windows, it has it's own way of doing things ... not important.
Running as a normal user in case of /infection/attack/mess up/exploit/ there is no easy way of installing additional code and make it run in Linux or have access to system /files/memory/hardware/, while running as Root the doors are already opened.
I am not good at explaining stuff, but in general, it is not a good idea to run as root although chances are very low that something will actually happen if you do not click and run unknown stuff/links/software/
4 years 8 months ago #235924 by tuxcnc
Security is important in servers and multi-access systems.
When the computer is cut off from the network, even by a router, and has only one user, there is no other hazard than the stupidity of the user.
Logging in as a guest and writing sudo before each line will not increase security.
But this is OFFTOPIC and let's talk better how to compile firmware to Colorlite v8.0 ....
4 years 8 months ago #235927 by Inga
Litex supports at least V8.0 of the 5A-75B board.
The colorlight_5a_75b.py from romanetz (THANK YOU!) can also be used on a 5A-75B V8.0 board when you change near line 348
platform = colorlight_5a_75b.Platform()
to
platform = colorlight_5a_75b.Platform(revision="8.0")
This will change the pinout for ethernet etc. to V8.0
Colorcnc not yet working but I can connect to the board.
Moderators: PCW, jmelson
Time to create page: 0.499 seconds
