How do you pass shielded servo motor cables through the cabinet wall/panel?
4 years 2 months ago #249111 by mgm
4 years 2 months ago #249112 by rodw
So if you use a ground clamp as suggested by above links above, how do you connect the shield to the drive connector terminal block?
4 years 2 months ago #249113 by mgm
The side on the Antieb is open with me
4 years 2 months ago #249115 by arvidb
You don't. Look at the Siemens video I linked above.
Note that you must still connect the ground conductor between the motor and the drive terminal, for safety.
4 years 2 months ago #249117 by mgm
I wouldn't know where to put the screen on my milling spindle. The junction box is in plastic.
A grounding cable is of course present!
4 years 2 months ago #249150 by rodw
The video shows use of a cable for servos with an additional ground conductor. In the case of a 4 wire stepper system, some quality stepper drives require the shield to be terminated at the drive as this diagram from the manual of a Lam Technologies DS1076A shows.
Ref:  www.lamtechnologies.com/Product.aspx?lng=EN&idp=DS1076
Elsewhere, they suggest the cable pass through the cabinet intact (eg. via a cable grommet)
When I've used these drivers, I've also terminated the shield to a copper grounding post on the enclosusre as shown here.
Note we've deliberately chosen steppers over servos in this application (plasma table) to leverage the massive acceleration steppers provide. (5 m/sec/sec or higher)
Moderators: PCW, jmelson
Time to create page: 0.400 seconds
