oh, looking ahead to the atc...
we have switches:
Z- bottom
Z+ top of working Z
Z home
ATC top tool changer rotation position
ATC area
so, from the earlier discussion on this:
Z axis is out working axis
W axis is our ATC axis
ignoring desires for continuous motion, we can when calling a tool change:
- stop main spindle
- simultaneously send spindle C axis home and go to Z axis home in coordinated motion ---- Z axis home = W axis home
- switch to W axis mode
- disregard or override z top limit switch during a tool change call
- move W axis to top (+80mm or whatever it is)
- rotate tool carousel cw or ccw and read its encoder to get to desired tool then hit its brake
- send W axis home
- switch back to Z axis normal mode
safety functions would need to be that when NOT in W axis tool change top position, atc carousel can NOT move. likewise when inside W axis travel area, SPINDLE may NOT spin.
this seems like it would work perfectly, missing only the desire to have a fluid chip to change motion - which we can try to devise at a later date. this older tc225 did not have that anyway, it stops the z before going to change. only the newer tc229 did it as a single motion.
this all doesn't sound that hard no?
