Mesa 7i76e setup help!
9 years 11 months ago #83025 by vmihalca
Replied by vmihalca on topic Mesa 7i76e setup help!
I have changed in the ini file the value of encoder scale 1440 to 360 and now the speed reading is correct.
Is there a bug or it it something I'm missing out?
9 years 11 months ago #83026 by jtc
Replied by jtc on topic Mesa 7i76e setup help!
image missing http://www.dynapar.com/uploadedImages/_Site_Root/Technology/Encoder_Basics/quadrature%20encoder%20image%202.jpg
with a 360 points per revolution quadrature encoder you will have 360*4 counts per revolution. If you turn one time the spindle it should count 1440.
9 years 11 months ago #83029 by vmihalca
I know, before I was using mesa board, the ini files was showing 1440, and the rpm was correct.
Now,with mesa, if in the file the value is 1440, the displayed rpm is 4 times lower.
9 years 11 months ago #83035 by andypugh
Replied by andypugh on topic Mesa 7i76e setup help!
Do you have a setting of "counter_mode = 1" somewhere in the HAL file?
9 years 11 months ago - 9 years 11 months ago #83040 by PCW
Replied by PCW on topic Mesa 7i76e setup help!
Yep
hm2_7i76e.0.encoder.00.counter-mode 1
So that will count 360 counts/turn with a 360 PPR encoder
(and will not count in both directions properly)
Note PnCConf will do this if you select "Single Input Encoder"
Meaning a "A" only encoder
Last edit: 9 years 11 months ago by PCW.
9 years 11 months ago #83199 by vmihalca
Yes, you were right, I had that "Single input encoder" checked, now its fine! :)
Time to create page: 1.131 seconds
