I got my cnc lathe retrofit up and running a few years ago, and now I'd like to add two mpg wheels for X and Z. The problem is that I'm unsure as to how to set my 7i92 into Software Process Data Mode 2 as described in the 7i76 manual on page 24. (In case you're wondering I think I did my retrofit before there was a 7i76e so I've got the 7i76 plugged into a 7i92... this is basically a hacked way of having a 7i76e).
What I would like to do now to improve the usability of my lathe is to wire up the two mpg wheels, with an increment selector switch (0.0001/click, 0.001/click, 0.01/click) and a few other buttons such as tool length offset set (X,Z) and G54 set (Z only since it's a lathe and there isn't much point in having the G54 not on the Z axis).
Here's a brief description of what I've already got wired up and working
spindle encoder into the high speed encoder/counter on the 7i76
X servo step/dir enable wired into axis 0
Z servo step/dir enable wired into axis 2
Tool changer (it's a geneva mechanism with a vane sense hall effect chip) wired in and working with some custom ladder logic
Spindle speed/dir wired up to the analog output of the 7i76
Here are my .hal and .ini files.
Any help would be greatly appreciated. AGAIN, THE ONLY ISSUE I HAVE IS I HAVE NO IDEA HOW TO ENABLE SOFTWARE PROCESS DATA MODE 2. I've seen stuff on here about setting serial=2, but I don't have any serial in my .ini or .hal
Here's a link with pics/videos of the lathe from when I got it and ripped out all the electrical guts to how it is now more or less with some pics/videos of parts I've made. Many thanks to all the contributors to linuxcnc and these forums without which it would have been impossible to get this up and running.
goo.gl/photos/NEwdRg1oR9mfZdzk8
Thanks,
Marc
