- Thank you received: 4
kcj wrote: Hello, glad to hear your are using and enjoying hazzy!
I don't think that is a hazzy related problem (though there are many). A return value of ###### for a variable generally means that that variable is not defined. Most likely you have not enabled the read from INI feature in your config file.
In the [RS274NGC] section of your INI file add FEATURES = 4, and see if that helps.
Code:[RS274NGC] FEATURES = 4
Cheers,
Kurt
