binary works - compilation not smoothly???
8 years 2 months ago #115767 by schorsch
...not so easy to find this, but finally solved....
axis-section must not be called [AXIS_0] or [AXIS_1] and so on, but [AXIS_X] and [AXIS_Y]
found some further small things:
the variable rot4thaxiskins.H1 needs to be negative in my case, since me machine origin is not the below but above the A Axis
finally the rotation orientation was swapped, easy to invert one pin
Thank you very much for you help, finally I need to get the different tool heights to work... will manage... thanks a lot
Schorsch
8 years 1 month ago #118139 by schorsch
I was finally able to get the 4th axis kinematics module (from the wiki) running and also the tool length probe. Just to remind you: I have an a axis installed on a xy table. spindle is fixed to z.
So far not working is 4th axis kinematics with tool length compensation. I figured out that G38.3 is not storing UVW coordinates…. should it??
I was able to set the cutter length compensation into the W axis, but it seems it has no effect. storing the cutter length Offset into z axis seems not be be correct as z is rotating.
I am wondering: When I am moving x,y,z axis the uvw coordinates are staying at 0, shouldn't be there any effect, too? Might there be a problem in the used kinematics module? Same vice versa.
Last Question:
I was able to figure out the actual height of the rotary axis is in z oder w coordinates and fixed in into the configuration as described in the wiki. For what do I need to probe the z and y (or the v and w) axis anymore, if the Pivot axis is fixed anyhow? From my point of view there should be either a button "Set y and z to rotary axis" or there should be a way to probe the rotary axis and then pass the probed coordinates into the kinematics module...hope you can help me to understand
Georg
8 years 1 month ago #118154 by andypugh
schorsch wrote: So far not working is 4th axis kinematics with tool length compensation. I figured out that G38.3 is not storing UVW coordinates…. should it??
I think so. The good thing about Open Source is that you can look at the code, not the docs.
github.com/LinuxCNC/linuxcnc/blob/0f91c5...otion/control.c#L543
caret_pos_fb is an EMCPose
github.com/LinuxCNC/linuxcnc/blob/0f91c5...motion/motion.h#L665
And that does contain UVW
github.com/LinuxCNC/linuxcnc/blob/0f91c5...ml_intf/emcpos.h#L19
But, note that it seems to log the feedback values.
What version of LinuxCNC are you using? I wonder if this is a fun Joints/Axes bug...
8 years 1 month ago #118158 by andypugh
Chatting on the IRC, we think it works.
What do you see as the "actual position" of the UVW axes when the probe finishes? Possibly the forward kins that you are using is not working in UVW?
8 years 1 month ago #118187 by schorsch
Concerning the version:
when I started this thread in july18 it was the master (LINUXCNC - 2.8.0~pre1). Because of your help I was able to compile by myself.
I just used G38.3 (either on z or on w axis) and checked #5061 to #5069 by using print (print, #5061 …). UVW is always 0. XYZ is ok.
Futhermore I wondered, (please check here: wiki.linuxcnc.org/cgi-bin/wiki.pl?Rot4thaxiskins ) About there lines in wiki.linuxcnc.org/uploads/rot4thaxiskins.c
pos->tran.x = m_x - to_x; pos->tran.y = m_y - to_y; pos->tran.z = m_z - to_z; pos->a = joint[3]; pos->b = joint[4]; pos->c = joint[5]; pos->u = joint[6]; pos->v = joint[7]; pos->w = joint[8];
I have only 4 Joints (and obviously the guy who has written the code, too). I don't care about B and C, but shouldn't UVW point to joints 0,1,2???
Currently I am displaying XYZAUVW in axis. Please tell me what should axis display when I'm moving X or Z axis?? Shouldn't V and W change ist values, too?
Georg
8 years 1 month ago #118192 by andypugh
What _are_ V and W?
They often refer to secondary axes (Lathe tailstock for example) and sometimes they are a second set of rotated coordinates (for example drilling along an angle defined by AB axes)
Time to create page: 0.289 seconds
