binary works - compilation not smoothly???
8 years 3 months ago #114029 by schorsch
here are the requested outputs.
I didn't mentioned before, that the machine is a stepper machine based on an an L297, but I guess you have seen this from the configs already.
Georg
8 years 3 months ago #114033 by andypugh
Note: Using LXRT Realtime
I think this is the problem. You need to run the configure script and choose RTAI realtime.
linuxcnc.org/docs/devel/html/code/buildi...ing_for_run_in_place
(You need to see what your usr/realtime..... folder is really called)
The following user(s) said Thank You: schorsch
8 years 3 months ago #114494 by schorsch
thank you very much.
I just tried it out very quickly.It seems to work now.
….now another topic comes up maybe you can help here too:
Using the configuration as shown above "axis" provides me 4 axis only! What do I have to do in order to get the others?
Remember I was trying to use the rot4thaxis kinematics, that means I have three joints for shifting one for rotationg (around x). I would expect at least XYZAVW (V and W will become my new Y and Z axis as YZ will be rotated around A)
Thank you again
Georg
8 years 3 months ago #114690 by andypugh
This is a combination of the num_joints passed to motmod in the hal (typically from NUM_JOINTS in the INI (but not necessarily), the AXES entry in the INI and (for preview display) the INI GEOMETRY.
Quite how they interact depends a bit on whether you are running 2.7 or 2.8. (Typing on a phone, hard to scroll back through to find if you said)
8 years 3 months ago #114715 by schorsch
thank you again.
I guess this was much easier than I thought: Seems one needs to have a referenced system in order to make UVW axis available... :-)
I didn't manage two things:
a) Kinematics with rot4thaxis seems to work. the correct axis are moving (Z axis moves Z and Y joint, W axis moves Z joint) but in the display e.g. Z and W are appearing as Z axis (are moving along the angle of the A axis)
b) homing works in the correct speed (as it was before) but after this all axis are limited to vel 60. This is damn slow.
I tried to change MAXVEL of axis or joints but no difference, is there another place where one can limit the speed?? Acceleration is very low too.
Georg
8 years 3 months ago #114959 by andypugh
There are velocity limits in the [TRAJ] section and you might also need to change the limits of the max-velocity slider.
Time to create page: 0.241 seconds
