binary works - compilation not smoothly???
8 years 1 month ago - 8 years 1 month ago #118201 by schorsch
as far as I understand I would assume that U is exactly X
V is exactly the second joint (meaning of the Y axis)
W is exactly the third joint (meaning of the Z axis)
But I'm a beginner in the context of multi-axis simultanous stuff. Please correct me, if I'm wrong
Shouldn't it be like this? I Always though UVW should be in the orientation of the cutter.
Let me ask a further Question. In my XYZA Coordinate System (by using the rot4thaxis kinematics) where do I have to apply the tool length Offset?? To the Z axis??? or to the W axis?
Georg
Georg
Last edit: 8 years 1 month ago by schorsch.
8 years 1 month ago #118202 by andypugh
UVW are completely different to XYZ. (otherwise, what is the point?)
Partly they are nothing more than a way to program the position of "something" from inside a G-code script.
What they actually mean is something that is defined by your configuration.
In TRT XYZAB systems W is often the tool length. But it doesn't have to be.
8 years 1 month ago - 8 years 1 month ago #118232 by schorsch
ok, seems I am misunderstanding something here….
My idea was to use XYZ+A for simulanous axis stuff (like milling a cylinder along the a axis, where the centerline of the cylinder is not the centerline of the a-axis)
And to use UVW+A for indexed machining (driving to A0 then do operations in uvw, then driving to A90 and so on).
I found other possibilities like switching between rotated coordinates (YZ depending on A) and trival coordinates (YZ not depending on A). See M128. Do I understand correctly that by switching between TCP and trivial coordinates (M128) I am switching the kinematics module between trival coordinates and rotated coordinates, too? How do I setup this???? What happens to the actual position when changing the coordinates?
Other point is the WCS? I think the only way to setup a WCS is to use the center line of the A axis as 0 for Y and Z, right?
I'm feeling free to use XYZ+A+UVW or XYZ+A + M128. Depending what you tell me, what is the best choice. I have to adapt the postprocessor anyhow
Georg
8 years 1 month ago #118293 by andypugh
schorsch wrote: Hi,
I don't think that is even necessary. Why can't you do both with XYZA?
The following user(s) said Thank You: schorsch
8 years 1 month ago #118303 by schorsch
ok... to be honest.... please don't laugh… I do not how to handle this in the postprocessor… but maybe you are right and it is easier to spend more time on this than to change the kinematics
Georg
8 years 1 month ago #118307 by schorsch
Shit it really took me only 30min to check the pptions of the postprocessor…. damn…
seems I really to not need UVW any longer
Thanks a lot for your hints!
Georg
PS for everyone else who is using Inventor HSM:
optimizeMachineAngles2(0) means TCP mode -> rotated coordinates needed
optimizeMachineAngles2(1) means non-TCP mode -> trivial coordinates needed
Thanks again
Time to create page: 0.227 seconds
