binary works - compilation not smoothly???
8 years 3 weeks ago #118648
by schorsch
Replied by schorsch on topic 4th axis kinematics with tool length compensation
Hi, Andy et al,
I managed again to run with 4 axis and 4 joints. And the postprocessor seems to produce good code, too. But finally I have problems to jog the A axis when using the trivial coordinates.
When multiply pressing on the jog button for the A axis very fast this occurs
It happens faster when using higher velocities...
I managed to hang the complete PC with this error. Really full stop. keyboard was blinking, couln't even move the mouse....
I do not have the same problem on any other axis
Is this a latency problem? I never had problems here
Thanks in advance
Georg
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/georg/Desktop/linux-cnc-dev-2018-10-10'
Machine configuration file is 'BF20-2018-10-10-dev.ini'
Starting LinuxCNC...
Found file(REL): ./stepper_xyza.hal
Found file(REL): ./standard_pinout.hal
Found file(REL): ./manualtoolchange.hal
note: MAXV max: 50.000 units/sec 3000.000 units/min
note: LJOG max: 50.000 units/sec 3000.000 units/min
note: LJOG default: 2.500 units/sec 150.000 units/min
note: AJOG max: 60.000 units/sec 3600.000 units/min
note: AJOG default: 12.000 units/sec 720.000 units/min
note: jog_order='XYZA'
note: jog_invert=set([])
Xlib.protocol.request.QueryExtension
on_abort executing
task: main loop took 0.145058 seconds
joint 3 following error
emc/task/taskintf.cc 944: Error on joint 3, command number 152
on_abort executing
on_abort executing
Thanks in advance
Georg
8 years 3 weeks ago #118652
Replied by andypugh on topic 4th axis kinematics with tool length compensation
Following error is likely to be that the A axis simply can't move as fast as commanded.
But it really shouldn't hang the machine. The whole point of LinuxCNC os to be rock-solid
8 years 3 weeks ago #118674
by schorsch
Hi, thanks a lot for your quick answer,
can't move that fast because of what?
I get drive it to much higher speeds, but when Pressing the button multiple times quickly after each other (like double-click speed) it crashed?? Which parameter do I have to change?
I do not understand this, as I can drive even higher stepper speeds at the linear axis without problems
Schorsch
Schorsch
8 years 3 weeks ago #118681
Some limit or other....
What step rate are you commanding? How does that compare to the actual step-pulse + step-space time?
What is the velocity limit on the stepgen? Accel limit? How does this compare to the axis limit?
schorsch wrote: can't move that fast because of what?
The following user(s) said Thank You: schorsch
8 years 2 weeks ago #118722
by schorsch
Great, seems to be fixed.
MAX_VELOCITY was larger than STEPGEN_MAXVEL, same with acceleration
couln't reproduce the error anymore, since I changed!
Thanks a lot
Georg
Thanks a lot
Georg
8 years 2 weeks ago - 8 years 2 weeks ago #118723
by schorsch
Hm....
Unfortunately, I'm running into a similar error when running in automatic mode
Most important stuff of my configuration are:
hm... I'm just realizing that I can run higher speeds in MDI than in the manual mode....why? Here it si crashing..maybe because of too high speed.... why it is like this...where can I set the total general limit?
thank you for any hint
Georg
on_abort executing
emc/task/taskintf.cc 944: Error on joint 3, command number 1418
on_abort executing
on_abort executing
[AXIS_A]
MIN_LIMIT = -9999.0
MAX_LIMIT = 9999.0
MAX_VELOCITY = 80.00
MAX_ACCELERATION = 125.0
[JOINT_3]
TYPE = ANGULAR
HOME = 0.0
MAX_VELOCITY = 40.00
STEPGEN_MAXVEL = 60
MAX_ACCELERATION = 110.0
STEPGEN_MAXACCEL = 125
INPUT_SCALE = 22.22222
FERROR = 10
MIN_FERROR = .25
MIN_LIMIT = -9999.0
MAX_LIMIT = 9999.0
HOME_OFFSET = 0.0
HOME_SEQUENCE = 3
[TRAJ]
AXES = 4
JOINTS = 4
COORDINATES = X Y Z A
HOME = 0 0 0 0
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_VELOCITY = 5.00
DEFAULT_ANGULAR_VELOCITY = 12.00
MAX_VELOCITY = 50.00
MAX_ANGULAR_VELOCITY = 40.00
DEFAULT_ACCELERATION = 50.00
MAX_LINEAR_ACCELERATION = 50.00
Georg
Last edit: 8 years 2 weeks ago by schorsch.
Time to create page: 0.116 seconds
