Raspberry Pi 4 Tutorial - fatal error
- Thank you received: 5928
I do not own and will not own a RPI4 in the near future, i still have two RPI3 to remind me how weak they are.
But seeing from a lot of posts lately, looks like the 4 is usable, so who knows....
Was there an answer to this? I just finished the RPi build mostly following the tutorial and saw this. I deleted the whole line. Did I do bad?I appear to have managed to install Raspbian RT, and I am now at the stage where I am installing LinuxCNC, where I am to edit out the two lines of dependencies in the debian/control.bottom.in file. However, the instructions don't quite match what I am seeing in the file:
python-vte | gir1.2-vte-2.91,
as opposed to just:
python-vte,
I am a complete novice, so I am not sure whether to remove the whole line, or just a portion.
John, a big thank you for putting these steps together.
Thanks,
-Loren
Like I said, I mostly followed the referenced tutorial except I built completely headless and used an xfce window manager. My servo latency is between 60000 and 90000. I’m running headless via VNC. Is that a source of latency?
That is how I plan to run linuxcnc. I have a Mesa 7i96.
Where should I look to reduce my latency?
Eddie
pdflatex failed
A possible reason for transformation failure is invalid DocBook
(as reported by xmllint)
Error: pdflatex compilation failed
make[1]: *** [../docs/src/Submakefile:443: ../docs/src/Master_Documentation.pdf] Error 1
make[1]: Leaving directory '/home/pi/emc/src'
make: *** [debian/rules:34: build-stamp] Error 2
dpkg-buildpackage: error: debian/rules build subprocess returned exit status 2
debuild: fatal error at line 1182:
dpkg-buildpackage -us -uc -ui failed
buildbot.linuxcnc.org/dists/buster/
For 2.8 - last updated June 30:
buildbot.linuxcnc.org/dists/buster/2.8-r...g19a686b67_armhf.deb
if you need the dev package as well:
if you need english docs as well:
buildbot.linuxcnc.org/dists/buster/2.8-r...3.g19a686b67_all.deb
For master (2.9) - last updated July 08:
buildbot.linuxcnc.org/dists/buster/maste...ge42b91e15_armhf.deb
buildbot.linuxcnc.org/dists/buster/maste...0.ge42b91e15_all.deb
after downloading to your Downloads directory, open a terminal and enter for each file you downloaded:
sudo apt install ~/Downloads/<the_name_of_the_file>.deb
sudo apt install ./<the_name_of_the_file>.deb
uild the book set list...
xsltproc -o doclist.txt --xinclude --xincludestyle doclist.xsl /home/pi/emc/docs/src/Master_Documentation.xml
Build the listings...
xsltproc -o listings.xml --xinclude --xincludestyle --param current.dir '/home/pi/emc/docs/src' /usr/share/dblatex/xsl/common/mklistings.xsl /home/pi/emc/docs/src/Master_Documentation.xml
xsltproc -o Master_Documentation.rtex --xinclude --xincludestyle --param current.dir '/home/pi/emc/docs/src' --param listings.xml '/tmp/tmplkwzHj/listings.xml' /tmp/tmplkwzHj/custom.xsl /home/pi/emc/docs/src/Master_Documentation.xml
XSLT stylesheets DocBook - LaTeX 2e (0.3.10)
Pixel unit not handled (replaced by pt)
Above that I don't see any errors, seams to all compile correctly. When I ran
sudo apt install ./<filename>
Cannot convert 'common/images/emc2-intro.png' to pdf
Cannot convert 'user/images/whatstep1.png' to pdf
Cannot convert 'gui/images/axis.png' to pdf
Cannot convert 'gui/images/touchy.png' to pdf
Cannot convert 'gui/images/gscreen-mill.png' to pdf
Cannot convert 'gui/images/gmoccapy_3_axis.png' to pdf
Cannot convert 'gui/images/ngcgui.png' to pdf
Cannot convert 'gui/images/axis-pyvcp.png' to pdf
Cannot convert 'gui/images/axis-gladevcp.png' to pdf
Cannot convert 'user/images/naive-cam.png' to pdf
inkscape -z -D --export-pdf=fig0.pdf /home/pi/emc/docs/src/user/images/mill-diagram_en.svg
inkscape -z -D --export-pdf=fig1.pdf /home/pi/emc/docs/src/user/images/lathe-diagram_en.svg
Image 'images/configuration-selector.png' not found
Cannot convert 'getting-started/images/configuration-selector.png' to pdf
Cannot convert 'config/images/stepconf-start_en.png' to pdf
Cannot convert 'config/images/stepconf-base_en.png' to pdf
Cannot convert 'config/images/latency-test_en.png' to pdf
Cannot convert 'config/images/stepconf-parallel-1_en.png' to pdf
Cannot convert 'config/images/stepconf-parallel-2_en.png' to pdf
Cannot convert 'config/images/stepconf-axis-x_en.png' to pdf
Cannot convert 'config/images/stepconf-x-test_en.png' to pdf
Cannot convert 'config/images/stepconf-spindle_en.png' to pdf
Cannot convert 'config/images/stepconf-options_en.png' to pdf
inkscape -z -D --export-pdf=fig2.pdf /home/pi/emc/docs/src/config/images/switch-nc-series_en.svg
inkscape -z -D --export-pdf=fig3.pdf /home/pi/emc/docs/src/config/images/switch-no-parallel_en.svg
Cannot convert 'config/images/pncconf-splash.png' to pdf
Cannot convert 'config/images/pncconf-basic.png' to pdf
Cannot convert 'config/images/pncconf-external.png' to pdf
Cannot convert 'config/images/pncconf-gui.png' to pdf
Cannot convert 'config/images/pncconf-mesa-config.png' to pdf
Cannot convert 'config/images/pncconf-mesa-io2.png' to pdf
Cannot convert 'config/images/pncconf-mesa-io3.png' to pdf
Cannot convert 'config/images/pncconf-mesa-io4.png' to pdf
Cannot convert 'config/images/pncconf-parport.png' to pdf
Cannot convert 'config/images/pncconf-axis-drive.png' to pdf
Cannot convert 'config/images/pncconf-scale-calc.png' to pdf
Cannot convert 'config/images/pncconf-axis-config.png' to pdf
Cannot convert 'config/images/pncconf-diagram-lathe.png' to pdf
Cannot convert 'config/images/pncconf-spindle-config.png' to pdf
Cannot convert 'config/images/pncconf-advanced.png' to pdf
Cannot convert 'config/images/pncconf-hal.png' to pdf
inkscape -z -D --export-pdf=fig4.pdf /home/pi/emc/docs/src/lathe/images/tool-positions_en.svg
inkscape -z -D --export-pdf=fig5.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-1_en.svg
inkscape -z -D --export-pdf=fig6.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-2_en.svg
inkscape -z -D --export-pdf=fig7.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-3_en.svg
inkscape -z -D --export-pdf=fig8.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-4_en.svg
inkscape -z -D --export-pdf=fig9.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-5_en.svg
inkscape -z -D --export-pdf=fig10.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-6_en.svg
inkscape -z -D --export-pdf=fig11.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-7_en.svg
inkscape -z -D --export-pdf=fig12.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-8_en.svg
inkscape -z -D --export-pdf=fig13.pdf /home/pi/emc/docs/src/lathe/images/control-point_en.svg
inkscape -z -D --export-pdf=fig14.pdf /home/pi/emc/docs/src/lathe/images/ramp-entry_en.svg
inkscape -z -D --export-pdf=fig15.pdf /home/pi/emc/docs/src/lathe/images/ramp-cut_en.svg
inkscape -z -D --export-pdf=fig16.pdf /home/pi/emc/docs/src/lathe/images/radius-1_en.svg
inkscape -z -D --export-pdf=fig17.pdf /home/pi/emc/docs/src/lathe/images/radius-2_en.svg
inkscape -z -D --export-pdf=fig18.pdf /home/pi/emc/docs/src/lathe/images/radius-3_en.svg
inkscape -z -D --export-pdf=fig19.pdf /home/pi/emc/docs/src/lathe/images/radius-4_en.svg
Cannot convert 'plasma/images/primer_torch-head.png' to pdf
Cannot convert 'plasma/images/primer_cut-angularity.png' to pdf
Cannot convert 'plasma/images/primer_volts-height.png' to pdf
Cannot convert 'plasma/images/primer_ohmic-sensing.png' to pdf
Cannot convert 'plasma/images/primer_hypersensing.png' to pdf
Cannot convert 'plasma/images/primer_thc-delay.png' to pdf
Cannot convert 'plasma/images/primer_kerf-cross.png' to pdf
convert /home/pi/emc/docs/src/gui/images/tool_estop.gif fig20.pdf
convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408.
Unexpected error occured
convert /home/pi/emc/docs/src/gui/images/tool_power.gif fig21.pdf
convert /home/pi/emc/docs/src/gui/images/tool_open.gif fig22.pdf
convert /home/pi/emc/docs/src/gui/images/tool_reload.gif fig23.pdf
convert /home/pi/emc/docs/src/gui/images/tool_run.gif fig24.pdf
convert /home/pi/emc/docs/src/gui/images/tool_step.gif fig25.pdf
convert /home/pi/emc/docs/src/gui/images/tool_pause.gif fig26.pdf
convert /home/pi/emc/docs/src/gui/images/tool_stop.gif fig27.pdf
convert /home/pi/emc/docs/src/gui/images/tool_blockdelete.gif fig28.pdf
convert /home/pi/emc/docs/src/gui/images/tool_optpause.gif fig29.pdf
convert /home/pi/emc/docs/src/gui/images/tool_zoomin.gif fig30.pdf
convert /home/pi/emc/docs/src/gui/images/tool_zoomout.gif fig31.pdf
convert /home/pi/emc/docs/src/gui/images/tool_axis_z.gif fig32.pdf
convert /home/pi/emc/docs/src/gui/images/tool_axis_z2.gif fig33.pdf
convert /home/pi/emc/docs/src/gui/images/tool_axis_x.gif fig34.pdf
convert /home/pi/emc/docs/src/gui/images/tool_axis_y.gif fig35.pdf
convert /home/pi/emc/docs/src/gui/images/tool_axis_p.gif fig36.pdf
convert /home/pi/emc/docs/src/gui/images/tool_rotate.gif fig37.pdf
convert /home/pi/emc/docs/src/gui/images/tool_clear.gif fig38.pdf
Cannot convert 'gui/images/axis-homed.png' to pdf
Cannot convert 'gui/images/axis-limit.png' to pdf
Cannot convert 'gui/images/axis-machineorigin.png' to pdf
Cannot convert 'gui/images/axis-outofrange.png' to pdf
Cannot convert 'gui/images/axis-currentandselected.png' to pdf
Cannot convert 'gui/images/touchoff.png' to pdf
Cannot convert 'gui/images/axis-mdi.png' to pdf
Cannot convert 'gui/images/axis-emc-status.png' to pdf
Cannot convert 'gui/images/manual-tool-change.png' to pdf
Cannot convert 'gui/images/axis-lathe-tool.png' to pdf
Cannot convert 'gui/images/axis-foam.png' to pdf
Cannot convert 'gui/images/holes.png' to pdf
Cannot convert 'gui/images/gmoccapy_5_axis.png' to pdf
Cannot convert 'gui/images/gmoccapy_ntb_preview_maximized_2.png' to pdf
Cannot convert 'gui/images/gmoccapy_ntb_preview.png' to pdf
Cannot convert 'gui/images/gmoccapy_with_left_box_in_edit_mode.png' to pdf
Cannot convert 'gui/images/gmoccapy_with_right_panel_in_MDI_mode.png' to pdf
Cannot convert 'gui/images/gmoccapy_mdi_hidden_keyboard.png' to pdf
Cannot convert 'gui/images/gmoccapy_getting_macro_info.png' to pdf
Cannot convert 'gui/images/gmoccapy_0_9_7_sim_hardware_button.png' to pdf
Cannot convert 'gui/images/manual_toolchange.png' to pdf
Cannot convert 'gui/images/gmoccapy_0_9_7_tool_info.png' to pdf
Cannot convert 'gui/images/sketch_auto_tool_measurement.png' to pdf
Cannot convert 'gui/images/gmoccapy_settings_button.png' to pdf
Cannot convert 'gui/images/gmoccapy_settings_appearance.png' to pdf
Cannot convert 'gui/images/gmoccapy_file_selection_dialog_with_keyboard.png' to pdf
Cannot convert 'gui/images/gmoccapy_settings_hardware.png' to pdf
Cannot convert 'gui/images/gmoccapy_settings_advanced.png' to pdf
Cannot convert 'gui/images/gmoccapy_lathe.png' to pdf
Cannot convert 'gui/images/gmoccapy_back_tool_lathe.png' to pdf
Cannot convert 'gui/images/gmoccapy_plasma.png' to pdf
Cannot convert 'gui/images/strange_numbers.png' to pdf
Image 'gui/images/tool_estop.gif' already converted as fig20.pdf
Image 'gui/images/tool_power.gif' already converted as fig21.pdf
Image 'gui/images/tool_run.gif' already converted as fig24.pdf
Cannot convert 'gui/images/ngcgui-db25-1.png' to pdf
Cannot convert 'gui/images/ngcgui-db25-2.png' to pdf
Cannot convert 'gui/images/ngcgui-db25-3.png' to pdf
Cannot convert 'gui/images/silverdragon.png' to pdf
Cannot convert 'gui/images/spartan.png' to pdf
Cannot convert 'gui/images/gaxis.png' to pdf
Cannot convert 'gui/images/industrial.png' to pdf
Cannot convert 'gui/images/tester.png' to pdf
Cannot convert 'gui/images/tester_editor.png' to pdf
Cannot convert 'gui/images/tkemc.png' to pdf
Cannot convert 'gui/images/tkemc-interp.png' to pdf
Cannot convert 'gui/images/tkemc-override-limits.png' to pdf
Cannot convert 'gui/images/tkemc-mdi.png' to pdf
Cannot convert 'plasma/images/plasmac_configurator_home_new.png' to pdf
Cannot convert 'plasma/images/plasmac_configurator_new.png' to pdf
Cannot convert 'plasma/images/plasmac_config.png' to pdf
Cannot convert 'plasma/images/plasmac_run.png' to pdf
Cannot convert 'plasma/images/plasmac_monitor.png' to pdf
Cannot convert 'plasma/images/plasmac_buttons_a.png' to pdf
Cannot convert 'plasma/images/plasmac_buttons_g.png' to pdf
Cannot convert 'plasma/images/plasmac_control_a.png' to pdf
Cannot convert 'plasma/images/plasmac_control_g.png' to pdf
Cannot convert 'plasma/images/plasmac_stats.png' to pdf
Cannot convert 'plasma/images/plasmac_extras.png' to pdf
Cannot convert 'plasma/images/plasmac_configurator_home_used.png' to pdf
Cannot convert 'plasma/images/plasmac_configurator_upgrade.png' to pdf
Cannot convert 'plasma/images/plasmac_configurator_reconfigure.png' to pdf
Cannot convert 'plasma/images/plasmac_material_main.png' to pdf
Cannot convert 'plasma/images/plasmac_material_dialogs.png' to pdf
Cannot convert 'plasma/images/plasmac_rs485_pmx.png' to pdf
Cannot convert 'plasma/images/plasmac_rs485_sunnix.png' to pdf
Cannot convert 'plasma/images/plasmac_rs485_dtech.png' to pdf
Cannot convert 'plasma/images/plasmac_reed_arc_ok.png' to pdf
Cannot convert 'gcode/images/offsets.png' to pdf
Cannot convert 'gcode/images/polar01.png' to pdf
Cannot convert 'gcode/images/polar02.png' to pdf
inkscape -z -D --export-pdf=fig39.pdf /home/pi/emc/docs/src/gcode/images/g2_en.svg
inkscape -z -D --export-pdf=fig40.pdf /home/pi/emc/docs/src/gcode/images/g2-3_en.svg
Cannot convert 'gcode/images/nurbs01.png' to pdf
inkscape -z -D --export-pdf=fig41.pdf /home/pi/emc/docs/src/gcode/images/g76-threads_en.svg
Cannot convert 'gcode/images/g76-01.png' to pdf
inkscape -z -D --export-pdf=fig42.pdf /home/pi/emc/docs/src/gcode/images/eight-holes_en.svg
inkscape -z -D --export-pdf=fig43.pdf /home/pi/emc/docs/src/gcode/images/twelve-holes_en.svg
inkscape -z -D --export-pdf=fig44.pdf /home/pi/emc/docs/src/gcode/images/g81mult_en.svg
inkscape -z -D --export-pdf=fig45.pdf /home/pi/emc/docs/src/gcode/images/g81ex1_en.svg
inkscape -z -D --export-pdf=fig46.pdf /home/pi/emc/docs/src/gcode/images/g81ex2_en.svg
inkscape -z -D --export-pdf=fig47.pdf /home/pi/emc/docs/src/gcode/images/g81_en.svg
inkscape -z -D --export-pdf=fig48.pdf /home/pi/emc/docs/src/gcode/images/g81a_en.svg
Cannot convert 'gui/images/image-to-gcode.png' to pdf
Cannot convert 'gui/images/i2g-roughing.png' to pdf
Cannot convert 'gcode/images/ToolTable-TouchOff.png' to pdf
inkscape -z -D --export-pdf=fig49.pdf /home/pi/emc/docs/src/gcode/images/comp-path_en.svg
inkscape -z -D --export-pdf=fig50.pdf /home/pi/emc/docs/src/gcode/images/comp02_en.svg
Cannot convert 'gcode/images/outside-comp.png' to pdf
Cannot convert 'gcode/images/inside-comp.png' to pdf
Cannot convert 'gui/images/tooledit.png' to pdf
Cannot convert 'gui/images/tooledit-sort.png' to pdf
Cannot convert 'gui/images/tooledit-columns.png' to pdf
Cannot convert 'config/images/servo-feedback.png' to pdf
Cannot convert 'config/images/pid-feedback.png' to pdf
Cannot convert 'config/images/latency-plot.png' to pdf
Cannot convert 'config/images/latency-histogram.png' to pdf
Cannot convert 'config/images/step-calc-inch-math.png' to pdf
Cannot convert 'config/images/step-calc-mm-math.png' to pdf
Cannot convert 'config/images/encoder-counts-math.png' to pdf
Cannot convert 'config/images/p-term.png' to pdf
Cannot convert 'config/images/i-term.png' to pdf
Cannot convert 'config/images/ff2.png' to pdf
Cannot convert 'config/images/output-offset.png' to pdf
Cannot convert 'config/images/scale-math.png' to pdf
Cannot convert 'config/images/calibration-1.png' to pdf
Cannot convert 'config/images/calibration-2.png' to pdf
Cannot convert 'config/images/calibration-3.png' to pdf
Cannot convert 'config/images/encoder-scale.png' to pdf
Cannot convert 'config/images/stepper-scale.png' to pdf
Cannot convert 'config/images/HomeAxisTravel_V2.png' to pdf
Cannot convert 'config/images/HomeAxisTravel_V3.png' to pdf
Cannot convert 'config/images/emc2-motion-homing-diag.png' to pdf
Cannot convert 'remap/images/debug_embedded_python.png' to pdf
Cannot convert 'gui/images/pyvcp_group.png' to pdf
Cannot convert 'gui/images/pyvcp_mypanel.png' to pdf
Cannot convert 'gui/images/pyvcp_axis_lathe.png' to pdf
Cannot convert 'gui/images/pyvcp_label.png' to pdf
Cannot convert 'gui/images/pyvcp_led.png' to pdf
Cannot convert 'gui/images/pyvcp_rectled.png' to pdf
Cannot convert 'gui/images/pyvcp_button.png' to pdf
Cannot convert 'gui/images/pyvcp_checkbutton.png' to pdf
Cannot convert 'gui/images/pyvcp_radiobutton.png' to pdf
Cannot convert 'gui/images/pyvcp_number.png' to pdf
Cannot convert 'gui/images/pyvcp_s32.png' to pdf
Cannot convert 'gui/images/pyvcp_bar.png' to pdf
Cannot convert 'gui/images/pyvcp_meter.png' to pdf
Cannot convert 'gui/images/pyvcp_spinbox.png' to pdf
Cannot convert 'gui/images/pyvcp_scale.png' to pdf
Cannot convert 'gui/images/pyvcp_dial.png' to pdf
Cannot convert 'gui/images/pyvcp_jogwheel.png' to pdf
Cannot convert 'gui/images/pyvcp_image01.png' to pdf
Cannot convert 'gui/images/pyvcp_image02.png' to pdf
Cannot convert 'gui/images/pyvcp_image_u32_01.png' to pdf
Cannot convert 'gui/images/pyvcp_borders.png' to pdf
Cannot convert 'gui/images/pyvcp_hbox.png' to pdf
Cannot convert 'gui/images/pyvcp_vbox.png' to pdf
Cannot convert 'gui/images/pyvcp_labelframe.png' to pdf
Cannot convert 'gui/images/pyvcp_table.png' to pdf
Cannot convert 'gui/images/pyvcp_tabs1.png' to pdf
Cannot convert 'gui/images/pyvcp_tabs2.png' to pdf
Cannot convert 'gui/images/pyvcp_tabs3.png' to pdf
Cannot convert 'gui/images/xyz_ACO.png' to pdf
Cannot convert 'gui/images/xyz_buttons.png' to pdf
Cannot convert 'gui/images/ptest.png' to pdf
Cannot convert 'gui/images/ptest-final.png' to pdf
Cannot convert 'gui/images/gs2_panel.png' to pdf
Cannot convert 'gui/images/pyvcp-rth.png' to pdf
Cannot convert 'gui/images/example-panel-small.png' to pdf
Cannot convert 'gui/images/example-tabbed-small.png' to pdf
Cannot convert 'gui/images/touchy-tab-33.png' to pdf
Cannot convert 'gui/images/glade-manual-small.png' to pdf
Cannot convert 'gui/images/hal-pin-change-66.png' to pdf
Cannot convert 'gui/images/checkbutton.png' to pdf
Cannot convert 'gui/images/radiobutton.png' to pdf
Cannot convert 'gui/images/button.png' to pdf
Cannot convert 'gui/images/hscale.png' to pdf
Cannot convert 'gui/images/spinbutton.png' to pdf
Cannot convert 'gui/images/Hal_Dial.png' to pdf
Cannot convert 'gui/images/JogWheel.png' to pdf
Cannot convert 'gui/images/SpeedControl.png' to pdf
Cannot convert 'gui/images/leds.png' to pdf
Cannot convert 'gui/images/progressbar2.png' to pdf
Cannot convert 'gui/images/hal_hbar.png' to pdf
Cannot convert 'gui/images/vscale.png' to pdf
Cannot convert 'gui/images/hal_meter.png' to pdf
Cannot convert 'gui/images/gremlin.png' to pdf
Cannot convert 'gui/images/combi_dro.png' to pdf
Cannot convert 'gui/images/iconview.png' to pdf
Cannot convert 'gui/images/gtk-tooledit.png' to pdf
Cannot convert 'gui/images/offsetpage.png' to pdf
Cannot convert 'gui/images/hal_sourceview.png' to pdf
Cannot convert 'gui/images/small-screenshot.png' to pdf
Cannot convert 'gui/images/vcp-actions.png' to pdf
Cannot convert 'gui/images/whoareyou.png' to pdf
Cannot convert 'gui/images/speed.png' to pdf
Cannot convert 'gui/images/oword.png' to pdf
Cannot convert 'hal/images/remote-start.png' to pdf
Cannot convert 'gui/images/vismach.png' to pdf
Cannot convert 'drivers/images/5i20-halpins.png' to pdf
Cannot convert 'drivers/images/pico-ppmc-math.png' to pdf
Cannot convert 'drivers/images/pluto-pinout.png' to pdf
Cannot convert 'drivers/images/pluto-step-pinout.png' to pdf
Cannot convert 'drivers/images/pluto_step_waveform.png' to pdf
Cannot convert 'drivers/images/GMsystem.png' to pdf
Cannot convert 'drivers/images/GM_PCIpinout.png' to pdf
Cannot convert 'drivers/images/GM_IOpinout.png' to pdf
Cannot convert 'drivers/images/GM_AXISpinout.png' to pdf
Cannot convert 'drivers/images/GM_AxisInterface.png' to pdf
Cannot convert 'drivers/images/GM_RefSignals.png' to pdf
Cannot convert 'drivers/images/GM_ENDSWpinout.png' to pdf
Cannot convert 'drivers/images/GM_RS485topology.png' to pdf
Cannot convert 'examples/images/spindle-math.png' to pdf
Cannot convert 'ladder/images/ladder_action_load.png' to pdf
Cannot convert 'ladder/images/ladder_action_loadbar.png' to pdf
Cannot convert 'ladder/images/ladder_action_out.png' to pdf
Cannot convert 'ladder/images/example_link_contact_coil.png' to pdf
Cannot convert 'ladder/images/example_link_contact_coil2.png' to pdf
Cannot convert 'ladder/images/example_link_contact_coil3.png' to pdf
Cannot convert 'ladder/images/Default_Sections_Manager.png' to pdf
Cannot convert 'ladder/images/Default_Section_Display.png' to pdf
Cannot convert 'ladder/images/Bit_Status.png' to pdf
Cannot convert 'ladder/images/watch_window.png' to pdf
Cannot convert 'ladder/images/Default_Symbols_names.png' to pdf
Cannot convert 'ladder/images/Editor.png' to pdf
Cannot convert 'ladder/images/Config.png' to pdf
Cannot convert 'ladder/images/AssignCompare-Ladder.png' to pdf
Cannot convert 'ladder/images/Assignment_Expression.png' to pdf
Cannot convert 'ladder/images/Comparison_Expression.png' to pdf
Cannot convert 'ladder/images/Config-io.png' to pdf
Cannot convert 'ladder/images/Config-com.png' to pdf
Cannot convert 'ladder/images/modbus_register_setting.png' to pdf
Cannot convert 'ladder/images/modbus_com_setting.png' to pdf
Cannot convert 'ladder/images/stepconf_ladder.png' to pdf
Cannot convert 'ladder/images/Section_Display_Grid.png' to pdf
Cannot convert 'ladder/images/Editor_NO_Input.png' to pdf
Cannot convert 'ladder/images/Section_Display_Build01.png' to pdf
Cannot convert 'ladder/images/Section_Display_Build02.png' to pdf
Cannot convert 'ladder/images/Section_Display_Build03.png' to pdf
Cannot convert 'ladder/images/SaveAs.png' to pdf
Cannot convert 'ladder/images/wrapping-counter.png' to pdf
Cannot convert 'ladder/images/extra-pulse-reject.png' to pdf
Cannot convert 'ladder/images/EStop_Section_Display.png' to pdf
Cannot convert 'ladder/images/axis_cl-estop.png' to pdf
Cannot convert 'ladder/images/Tmr_Section_Display.png' to pdf
Cannot convert 'hal/images/hal_circuit_concept.png' to pdf
Cannot convert 'hal/images/HAL_Configuration.png' to pdf
Cannot convert 'hal/images/signal-direction.png' to pdf
Cannot convert 'hal/images/halmeter-select.png' to pdf
Cannot convert 'hal/images/halmeter-1.png' to pdf
Cannot convert 'hal/images/halscope-01.png' to pdf
Cannot convert 'hal/images/halscope-02.png' to pdf
Cannot convert 'hal/images/halscope-03.png' to pdf
Cannot convert 'hal/images/halscope-04.png' to pdf
Cannot convert 'hal/images/halscope-05.png' to pdf
Cannot convert 'hal/images/halscope-06.png' to pdf
Cannot convert 'hal/images/halscope-07.png' to pdf
Cannot convert 'hal/images/halscope-08.png' to pdf
Cannot convert 'hal/images/halscope-09.png' to pdf
Cannot convert 'hal/images/halscope-10.png' to pdf
Cannot convert 'hal/images/halscope-11.png' to pdf
Cannot convert 'hal/images/hal-meter01.png' to pdf
Cannot convert 'hal/images/hal-meter02.png' to pdf
Cannot convert 'hal/images/sim_pin.png' to pdf
Cannot convert 'hal/images/simulate_probe.png' to pdf
Cannot convert 'hal/images/hal-histogram.png' to pdf
Cannot convert 'hal/images/halshow-1.png' to pdf
Cannot convert 'hal/images/halshow-3.png' to pdf
Cannot convert 'hal/images/halshow-2.png' to pdf
Cannot convert 'hal/images/halshow-4.png' to pdf
Cannot convert 'hal/images/stepgen-block-diag.png' to pdf
Cannot convert 'hal/images/stepgen-type0.png' to pdf
Cannot convert 'hal/images/stepgen-type2-4.png' to pdf
Cannot convert 'hal/images/stepgen-type5-10.png' to pdf
Cannot convert 'hal/images/stepgen-type11-14.png' to pdf
Cannot convert 'hal/images/encoder-block-diag.png' to pdf
Cannot convert 'hal/images/pid-block-diag.png' to pdf
Cannot convert 'hal/images/velocity-01.png' to pdf
Cannot convert 'hal/images/softstart-scope.png' to pdf
Cannot convert 'motion/images/bipod.png' to pdf
Cannot convert 'motion/images/kinematics-math-01.png' to pdf
Cannot convert 'motion/images/kinematics-math-02.png' to pdf
Cannot convert 'motion/images/kinematics-math-03.png' to pdf
Cannot convert 'motion/images/kinematics-math-04.png' to pdf
Cannot convert 'motion/images/kinematics-math-05.png' to pdf
Cannot convert 'motion/images/kinematics-math-06.png' to pdf
Cannot convert 'motion/images/kinematics-math-07.png' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-001.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-002.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-003.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-004.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-005.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-006.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-007.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-008.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-009.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-010.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-011.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-012.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-013.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-014.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-015.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-016.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-017.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-018.jpg' to pdf
Cannot convert 'motion/5-axis-figures/equation__1.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-1.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__2.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__3.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-2.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__4.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__5.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-3.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-4.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__6.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__7.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__8.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__9.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__10.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__11.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__12.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__13.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__14.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__15.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__16.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__17.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-5.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-6.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__18.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__19.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__20.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__21.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__22.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__23.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__24.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__25.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__26.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__27.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-7.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-8.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__28.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__29.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__30.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__31.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__32.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__33.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__34.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__35.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__36.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__37.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__38.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-9.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-10.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-11.png' to pdf
Build Master_Documentation.pdf
built-in module pdftex registered
no support found for ifthen
no support found for ifxetex
no support found for fontspec
no support found for xltxtra
no support found for fontenc
no support found for inputenc
no support found for fancybox
built-in module makeidx registered
no support found for emc2
building additional files...
checking if compiling is necessary...
the output file doesn't exist
pdflatex -interaction=batchmode Master_Documentation.tex
pdflatex failed
Erroa2x: ERROR: "dblatex" -t pdf -p "/etc/asciidoc/dblatex/asciidoc-dblatex.xsl" -s "/etc/asciidoc/dblatex/asciidoc-dblatex.sty" -P doc.publisher.show=0 -P latex.output.revhistory=0 -s ../docs/src/emc2.sty -P latex.hyperparam=colorlinks,linkcolor=blue,filecolor=blue,urlcolor=blue,citecolor=blue -V "/home/pi/emc/docs/src/Master_Documentation.xml" returned non-zero exit status 1
What error did you get?Thank you for your help Phill. Installing those files didn't do the trick.
I am not following, did you compile on one machine then copy the deb fiiles to another?Above that I don't see any errors, seams to all compile correctly. When I ran
after copying the files onto the pi could I have installed them in the wrong place or does the nature of that call put the files where they need to go for the build?
EDIT: I see that neither 2.8 or master packages are building correctly on the Buildbot as well.
If you want to compile locally why not just do a run in place install and forget about using packages. If you want to use packages then use the prebuilt ones I linked to earlier.
