9 years 7 months ago - 9 years 7 months ago #90382 by newbynobi
Hallo Dan,
very nice machine and nice GUI B)
Of course I will help you as much as I can.
I would recommend to use a custom embedded panel for that, and place that one in
box_custom_4 (will introduce your glade file right of spindle_frame)
you can find more documentation here
Just use glade to make your panel (i.e. spindle_brake.glade) with the needed hal widgets and include it like so:
gladevcp -x {XID} -H spindle_brake.hal spindle_brake.glade
You need to do the corresponding hal connections in spindle_brake.hal
Norbert
Last edit: 9 years 7 months ago by newbynobi.
9 years 7 months ago #90411 by dhanger
Okay, I see I have some reading and testing to do. I haven't done very much 'under the hood' work with LinuxCNC, but I've already read a lot so I have some understanding. I'll shout if I run into any problems, thanks.
9 years 7 months ago #90417 by Patrik T
Hello, thanks for your support.
Here are files of a config. I had to add some .txt extensions to be able to upload them.
There is a ui panel with buttons and callbacks, and a python handler. The callbacks are connected and ready to use. The problem that I want help with is to get them to clear, pan and zoom in the Gmoccapy gremln preview. There is also a button to reload the program in Gmoccapy that I need help with.
I do off course not expect you to do all the buttons, just help with one that has contact with the gremlin and the one that reloads the program.
Best regards
Patrik
9 years 7 months ago #90418 by Patrik T
I am not sure the upload was successful so I try it again.
9 years 6 months ago #91282 by Patrik T
Hi Norbert
Have you had any luck finding a solution that would enable me to access the Gmoccapy gremlin preview methods from the python handler of a custom tab, like e discussed earlier?
Best regards
Patrik
9 years 6 months ago #91318 by newbynobi
I am on holiday, no time to look at this yet.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.545 seconds
