- Thank you received: 217
Yeh, thats the problem. As soon as you document something like that step by step it seems to go on forever!Rods guide is quite detailed (that's good!), so it looks more complicated than it is at first sight. So don't hesitate
Well, I just installed Debian 12 - Bookworm and LinuxCNC 2.9.HansU post=270040 userid=27132
Geosec post=270021 userid=33136Ticking the Ignore Limits box allows me to turn the machine back on and move off the limit switch, but the check box is not automatically cleared
However this should be fixed in 2.9. If you find the time and try the 2.9 version I would appreciate your feedback.
It's a typical 3 axis mill (G0704). Each axis has 3 switches, minimum and maximum limits and a home switch. The "switches" are PNP, normally closed inductive proximity sensors. They are wired to a Mesa 7i76E FPGA card, each to a separate input terminal. They are powered by the same 24VDC Meanwell power supply that powers the Mesa card. I set them up using PncConf Wizard selecting the appropriate selection(s), i.e. => Mesa Card 0 => 7I76 I/O (SS# 0) => [function] Limits => Main Axis => X Maximum Limit... and so on for the minimums and homes.Limits should always trigger, no matter what.
Probably something not right in the config.
How many switches per axis/joint?
how are they wired and to what board?
