THCAD-10
8 years 2 months ago #116083 by tommylight
Replied by tommylight on topic THCAD-10
RodW has posted his several times on this forum, just search for him.
8 years 2 months ago #116085 by kb8wmc
Replied by kb8wmc on topic THCAD-10
thanks tommylight
8 years 2 months ago #116239 by rodw
Replied by rodw on topic THCAD-10
tommylight wrote: RodW has posted his several times on this forum, just search for him.
Been so busy have not been here for a while. My solution to scaling the THCAD-10 was to write a component See this thread with documented example HAL connections.
forum.linuxcnc.org/plasma-laser/32585-scalethcad-component
8 years 2 months ago - 8 years 2 months ago #116406 by BigJohnT
Replied by BigJohnT on topic THCAD-10
I've been so busy as well. I'm currently using a 5i25, 7i76 and THCAD-10 on my plasma. I've attached my current configuration files as well as the current thc component I use.
Oddly enough you have to right click on the files and select save link as.
JT
Last edit: 8 years 2 months ago by BigJohnT.
The following user(s) said Thank You: kb8wmc
8 years 2 months ago #116436 by islander261
Replied by islander261 on topic THCAD-10
Hi
I use a7i76E with the THCad-10 on my plasma. I run it 5 days a week and the THC works well. Please see my basic hal code to get the arc voltage without any custom hal components. It is kind of messy because it has both divide by one and divide by 32 THCad settings in it left over from trouble shooting THC problems. I had no need to run in the divide by 32 mode for noise reduction.
#******************* # THC stuff #******************* # ---Encoder Setup for THC-- setp hm2_7i76e.0.encoder.00.counter-mode 1 #filter mode now set to true for divide by 32 THCad mode #setp hm2_7i76e.0.encoder.00.filter 1 #filter mode now set to false for divide by 1 THCad mode setp hm2_7i76e.0.encoder.00.filter 0 setp hm2_7i76e.0.encoder.00.scale -1 net thc-vel-in hm2_7i76e.0.encoder.00.velocity #********************************* #use base components for getting arc voltage #******************************** #these settings are scaling encoder counts to arcvolts using scale component #Value for my THCad card and voltage divider (18.94181:1) setp scale.arcvolts.gain .0002238191 #Value for my THCad card 124400 * .0002238191*-1 setp scale.arcvolts.offset -27.843 #now using divide by 32 mode per PCW rcomended setup so all scalling values are divided by 32 #setp scale.arcvolts.gain .007162211 #setp scale.arcvolts.offset -27.843 net thc-vel-in => scale.arcvolts.in net scaled_arcvolts <= scale.arcvolts.out
8 years 2 months ago #116455 by kb8wmc
Thanks much JT...I got the files on brother's plasma table modified over in a couple hours to conform to your recent code...We won't be able to test until this next weekend as his compressor is down right now...Part to fix should arrive by then we hope...
I have a question...I see that there is a "thc_volts" component listed under the category of "Volts Test" in the hal file...
1. What is it used for?
2. Is it necessary to inter-operation with machine?
3. How does it work?
4. Where can I get in order to install it?
Another question: As we are using your post-processor and Sheetcam with the M68 Q-voltage picked up and displayed in the pyvcp panel? I loaded a file in Axis and the voltage remained at 0 in the display...
Can't wait to test and see the THC working...
thanks in advance...
Mike
