I am still having same problems with the THC working properly...
When attempting to perform cut with thc-pid active the machine goes through all the motions up to following the tool path...There it goes haywire...
I initialize the start arrow button with a tool path to be cut...The machine then properly performs a touch off, then moves to proper pierce height...The arc then starts and the torch moves to proper cut height, then almost immediately or upon first movement onto the tool path, the torch quickly raises and loses its arc...
I am just guessing but it seems to me that the THC is actually working, thereby causing the torch to raise to the point where the arc is lost...There is so little time between the events that I cannot get any useful data from the hal configuration... Another guess is that my THC settings are not properly tuned...The scale offset value is the only value that I am confident with as that value (118000) was taken from the sticker on the back of the THCAD-10...
Any input is welcome...Either I am not seeing something of settings are incorrect, or something that I do not even suspect...
Thanks in advance
Mike
