THCAD-10
8 years 2 months ago #116743 by kb8wmc
Replied by kb8wmc on topic THCAD-10
PCW...Any tips or relevant how to's for calculating the scale?
I have not checked the output voltage frequency...Can you point me in the right direction to a howto for doing this check?
Tommylight...I think I just learned something here from you on the actual voltage...
Thanks to you both
Mike
8 years 2 months ago #116744 by PCW
Replied by PCW on topic THCAD-10
Can you post your existing hal/ini files?
8 years 2 months ago #116746 by kb8wmc
PCW, sure can provide them...
The plasma.hal file is pretty much stripped down and contains mostly motion related data...The postgui contains mostly the pins and connections to the display panel...The thc.hal file is where most all of the THC related parts are...
Thanks in advance
8 years 2 months ago #116748 by PCW
I dont see that the encoder scale is set anywhere
If the thc-pid comp expects positive numbers and direct frequency inputs you probably need to set the encoder scale to -1
You can easily check if frequency is positive with halmeter
8 years 2 months ago #116749 by kb8wmc
I am back at home right now PCW...I will have to get back at it tomorrow...
I have followed JT's setup pretty much to the "T" or so I believe, and I believe JT developed the thc-pid component, so I am making the assumption that all is as it should be with his component...I don't know what to do or say about setting the encoder scale as I see no reference to it in JT's files, unless I just don't recognize it...
thanks bunches PCW
Mike
8 years 2 months ago #116788 by kb8wmc
PCW, I have re-read the THCAD-10 pdf manual several times now and have some questions...
In the calibration section, if I comprehend this correctly, the output frequency at 0V is given from the sticker on back of THCAD-10 card (118,000 = FZERO)...The output frequency for 10V is also provided on card (924,000 = FFS)...In the given formula FZERO is subtracted from FFS providing a resultant (806,000)...
I am only assuming that VFS has in this case the value of 10...
Now it gets fuzzy to me in that within the encoder setup portion of the thc.hal file, I have the "scale offset" as 118,000...My present opinion is that I am incorrect as to the use of what I have set as the "scale offset" number...
Again, I make an assumption, that FOUT is somehow arrived at by using a 9V battery on the input side of the THCAD-10 but I am uncertain...I am not electrical guru but I can follow simple instructions...What I read on the pdf is not clear to me...
Any guidance would be appreciated and I am sure I will have more questions...
Mike
