robertspark wrote: I've just stuck my ammeter on the PMX45 and this time I got the current rising to about 15.1mA in a little over a minute.
robertspark wrote: Load current 0.0025...6 A (i.e. 2.5mA minimum current? .... possible issue??))
tommylight wrote: Interference, missing ground, ground loops, wiring ( boards not at the same potential ), etc.
Those are the issues in all of the above, i would hate to see this topic concluding SSR are not good for plasma as that is the way it is going so far, besides Phill and Rod who are using them, but reading the whole topic Rod seems to be against them and for them !?!?!?
SSR are used in all kinds of switching environments, from welders (have one) to high power metal melting furnaces, but plasma is altogether another beast due to so much interference it creates. So i do agree with PCW that using an SSR should work properly.
Normal relays are immune to any interference, so using them is the easy way out, and if everything else works then by all means do use them. Chasing the above mentioned issues can take long and sometimes can not be found with a magnifying glass, but most of the time it is something simple in the wiring causing such hiccups.
Moving the ground clamp to vary the failure rate should have been a very good clue something in the wiring is not OK.
snowgoer540 wrote:
Should be able to use an appropriate SSR in place of a mechanical relay and can successfully use one are two totally different things. I agree in theory they're better, that's why I tried one. In practice, for me, and a few others, they do not work in this application.
tommylight wrote: I read everything so i know there are 3 cases by now, pretty sure we are going to see more.
