Homemade, cheap, plasma CNC
4 years 11 months ago #225649 by tommylight
To test the float switch all you have to do is move the torch up by hand and watch the screen, the "float" LED should turn on even when machine is disabled.
I think i already mentioned this, but probably the float switch pin is not in HAL where it should be.
4 years 11 months ago #225654 by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Thanks Tommy,
the 'float' led doesn't light up.
I have checked the Hal show and can see it working so know the mechanical side of things is right.
I setup using PnCConf wizard.
Can you share a copy of your HAL file and what it should look like, I have tried to use what was working in PlasmaC Hal file, however haven't got this right yet.
Cheers
4 years 11 months ago #225658 by tommylight
Yes i can but it will confuse you even more as all my Plasma configs are hand edited.
I will upload them when i get to the machines.
4 years 11 months ago #225664 by phillc54
In your Hal file you should a a line something along the lines of:
net plasmac.float <= your-hal-pin-that-lights-up
The following user(s) said Thank You: RNJFAB
4 years 11 months ago #225666 by RNJFAB
File Name: PLASMAhal.txt
File Size:13.99 KB
My Hal file
Key lines
85 # --- PROBE-IN ---
86 net float-switch    <=  hm2_7i96.0.gpio.008.in
311 #  ---probe signal---
313 net float-switch     =>  motion.probe-input
334 et plasmac:float-switch-out     db_float.out                =>  plasmac.float-switch
4 years 11 months ago #225667 by phillc54
313 should be:
net float-switch => db_float.in
