Homemade, cheap, plasma CNC
4 years 11 months ago #227142 by phillc54
Cool, your last post mentioned PlasmaC and that does the buttons a little bit differently than QtPlasmaC, we probably should have called it something that would be a bit less confusing. Anyhow it is what it is now ...
4 years 11 months ago - 4 years 11 months ago #227143 by rodw
Replied by rodw on topic Homemade, cheap, plasma CNC
try something like
net laser:switch qtplasmac.laser_on => my-mesa-output-pin
Last edit: 4 years 11 months ago by rodw.
4 years 11 months ago #227145 by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
File Name: custom.hal.txt
File Size:572 B
File Name: PLASMA.hal.txt
File Size:14.3 KB
File Name: PLASMA.ini.txt
File Size:6.05 KB
Still no dice.
4 years 11 months ago #227148 by rodw
File Size:572 B
File Size:14.3 KB
File Size:6.05 KB
Still no dice.
not what I said. you have created a signal but its not connected to anything . Try
net plasmac:laser-switch qtplasmac.laser_on => hm2_7i96.0.ssr.00.out-01
4 years 11 months ago #227151 by rodw
This is where people get confused. you can't connect computer chips pin to pin. You have to use a wire or solder trace.
so with lcnc components, you replace the wire with a signal which can be whatever name you like.
To me it always makes it clearer to do it on two lines to make it clearer, particularly when starting out.
# create a signal from an output pin net plasmac:laser-switch <= qtplasmac.laser_on # connect the signal to an input pin net plasmac:laser-switch => hm2_7i96.0.ssr.00.out-01
the <= and => are not required, they just are designed to make the meaning clearer by showing a direction (eg input or output)
4 years 11 months ago #227152 by phillc54
That is why I find it easier if it is all on one line, that way you know it is all in one place.
Time to create page: 0.164 seconds
