Homemade, cheap, plasma CNC
4 years 7 months ago #237049 by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Look for:
g92_offset
tool_offset
Both are 0.000, 0.000, 0.000
Is this the right place??
4 years 7 months ago #237050 by phillc54
Use the WATCH tab and it should be plasmac.safe-height
4 years 7 months ago #237051 by RNJFAB
Confirmed. It changes as i change the safe height in the GUI
4 years 7 months ago #237055 by phillc54
In Halshow select the SHOW tab and then look in Signals on the left panel and select the signal named plasmac:axis-position and see what pins are linked.
I dont see the link in your hal file but the error you are getting doesn't seem to relate.
4 years 7 months ago #237059 by RNJFAB
4 years 7 months ago #237060 by phillc54
That was plasmac:axis-x-position, there should be one named plasmac:axis-position
If you cannot find it then edit your hal file and immediately after this line:
# ---JOINT ASSOCIATED WITH THE Z AXIS---
add this:
net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position
It seems to be missing from your posted hal file but I wanted to make sure.
The following user(s) said Thank You: RNJFAB
Time to create page: 0.210 seconds
