Homemade, cheap, plasma CNC
4 years 7 months ago #236516 by snowgoer540
A helpful visual of the different heights:   linuxcnc.org/docs/devel/html/plasma/qtpl...tml#qt_initial-setup
The following user(s) said Thank You: tommylight, RNJFAB
4 years 7 months ago #236528 by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Thanks guys,
I have changed the safe height to 100 and still get the same error.
The z axis only goes up to 8.4mm before travel. And gives the warning after the first cut of a job.
No doubt I have set something, somewhere and now I can’t find it to fix it.
4 years 7 months ago #236562 by phillc54
I set up a sim with the same parameters for the Z axis that you posted and it works fine with the plasmac example files.
Can you post the backup of your config.
Can you post a Gcode file it errors with.
Can you pinpoint exactly on the Gcode file where it errors.
The following user(s) said Thank You: RNJFAB
4 years 7 months ago #236837 by RNJFAB
Thanks Phil,
config
File Name: PLASMA.pncconf
File Size:309.15 KB
G code. error happens at line 17. once touchoff has been completed.
File Name: DGRIMMSIGtap.txt
File Size:21.43 KB
4 years 7 months ago #236880 by snowgoer540
FWIW, this g-code file ran fine on my sim machine (imperial machine though), but without a backup of your config, it's impossible to simulate your machine.
To get a backup of your config, click "BACKUP CONFIG" in the parameters (or settings if your screen is 4:3) tab.  Upload the resulting file here. :)
4 years 7 months ago #236966 by RNJFAB
File Name: PLASMA_V1....3.tar.gz
File Size:13.99 KB
Time to create page: 0.453 seconds
