- Thank you received: 905
It seems quite complicated. Has anyone done it with +-10v control? I want to try it on my lathe.
That sounds interesting. How are you planning to couple the secondary motor to the spindle?At a later stage, I plan to add an additional 1kW servo motor, which will operate in torque mode to act as a dynamic load on the main 7kW motor. This will increase the system's rigidity. Currently, I'm using the encoder from the main motor
