- Thank you received: 12
Does PnCConf know about the 7i49? If it does then everything will probably be fairly easy.snoozer77 wrote: Was just wondering what process you recommend for doing some initial setup and testing using the 1 drive and motor i have at home? Im using the toolchange motor and drive as it is single phase and i can work on it at home easier.
If you can find something like 5i24_RMSVSS6_6.bit then that would be better:I have flashed the 5i24 with the 5i24_sv6_7i49 configuration.
That's probably the best place to start.Should i now setup a config in the wizard with 5i23 and edit as required by hand?
