Zenford Zeigler Retrofit
8 years 3 months ago #114346 by snoozer77
Replied by snoozer77 on topic Zenford Zeigler Retrofit
i don't think you need to connect them at all (for testing), it is a fault signal to your controller. When no faults exits, Circuit between pin 20, 21 will be closed. when you have a drive fault, pins 20 and 21 will be open circuit. I would not connect anything for testing, then connect together with axis drive fault circuit (to control) after testing. Will have to get the Hydraulic pic tonight.
8 years 3 months ago #114448 by snoozer77
Not a very good pic. First time i have actually looked at the hyd circuit.
8 years 3 months ago #114450 by snoozer77
My pile of axis drives. Out of these 9 drives, i only managed to get 3 operational. The other 6 have various issues. 2 were full speed as soon as the drives were enabled, 2 show over volt over current led's and the other 2 have control curcuit shorts to ground. Would love to get 5 out of the 9 running.
8 years 3 months ago #114460 by tommylight
Replied by tommylight on topic Zenford Zeigler Retrofit
The 2 that run when enabled most probably have faulty power stage transistors ( or mosfets or IGBT ), that can easily be changed. Do you have a soldering iron and a DVM ?
The following user(s) said Thank You: snoozer77
8 years 3 months ago - 8 years 3 months ago #114465 by snoozer77
Hi Tommy,
I dont have alot of electronics gear, but i do have them. Im pretty new to drive electronics, trying to read as much as i can to get an understanding of what im looking at. Its definately nice to have a reference running drive to check components.
If you have any suggestions on what to look for, i would be very greatfull.
Im happy to post pics (of drive electronics) if that helps anyone familiar with my drive components.
Cheers
Matt
Last edit: 8 years 3 months ago by snoozer77.
8 years 3 months ago #114470 by tommylight
Most probably the parts that are screwed down to the heat sink should be 4 of the same for DC drives and 6 of them for 3 phase drives. Some have just a module so it is easier to swap but much more expensive.
Time to create page: 0.445 seconds
