Zenford Zeigler Retrofit
8 years 3 months ago #114273 by snoozer77
Replied by snoozer77 on topic Zenford Zeigler Retrofit
No probs. Will post when i get home. I would like to get the one in nsw. But transport will prob be as much as the machine..
8 years 3 months ago #114275 by snoozer77
Do you have the original transformer, contactor, etc for the spindle?
8 years 3 months ago #114276 by snoozer77
Found drawings at work. Pin 20 and 21 are 24v drive fault. line 2381 (24v+) comes through a set of limit switches, through the axis servo drives, into the spindle drive and comes out pin 21 (if no fault) through wire 4230 to the controller. All other conections are shown. hopefully you have transformer (T2), contactor (K4) and inductor (L1). This drawing is for resolver feedback. apparently, some of the later spindles went to AC with encoder feedback. Not sure if your controll will accept resolver, but im not farmiliar with the CSLabs control.
Yell out if there is anything else you need to know. I will try help.
Cheers
Matt
8 years 3 months ago #114278 by Marz1987
Replied by Marz1987 on topic Zenford Zeigler Retrofit
Champion that great thanks,
got the transformer and inductor but not the contactor by the looks.
Got quoted $1500 for the freight for the sydney machine, deciced that money would be better spent on electronics on this machine.
I can get hold of a dc siemens simdrivee 611 spindle driver as my next option if the hyperloop is a no go.
Cheers.
P.s sorry to hijack your thread!.
8 years 3 months ago #114279 by snoozer77
No probs. Nice to see another one getting fixed up.
8 years 3 months ago #114345 by Marz1987
Hi Snoozer,
would you be able to photo the wiring for the hydraulics and lube systems. makes it heaps easier than trying to trace everything!. On the hyperloop I'm working out how we can bypass pins 20 and 21 signals, do you think if put a jumper between them it will give it the correct signal or do they require 24v ,
Cheers
Marcel.
Time to create page: 0.472 seconds
