Forum Header
Help with "Step Timing Calculator"
13 years 4 months ago #35383 by Todd Zuercher
If more than one or two, I'd say the probability is quite high.
If you need to replace balls, be careful they must be very precisely sized.
13 years 4 months ago #35393 by cncbasher
as todd says be careful on size , the track should be just about full , if you jam an extra one in , you'll find it will lock up and not move
the balls do track along the slide and move around , so an odd one missing wont harm directly , although i'd say more than 2 missing could cause intermittent problems
13 years 4 months ago #35399 by Todd Zuercher
If you need more balls. I'd suggest contacting the screw manufacturer. You will need the serial number from the nut and or maybe the screw. Usually these numbers are hand engraved on the nut somewhere. They should be able to tell you the size and probably supply you with some replacements.
1 year 2 months ago - 1 year 2 months ago #332774 by richcolvin
The link in the html manual does not work. Is this spreadsheet still available?
Last edit: 1 year 2 months ago by richcolvin.
1 year 2 months ago #332792 by Aciera
1 year 2 months ago #332861 by richcolvin
This is what comes up from that link
Time to create page: 0.139 seconds
