Hi Todd,
Yes, you did share timing with me. I think it was 10,000 if my memory is correct.
I believe that is what was used.
I have been reluctant to bother you folks here on the forum with the situation I'm dealing with.
I thought I should explore the instructions in the manual first.
This subject is surprisingly deep (so many things to consider), if I was going to need to have this knowledge on a daily basis I could see pursuing all of this, but as I only need it to get things going for now I submit it seems more prudent to just share my issue and revisit the details later.
When I run the “testngc” file under “Step Timing” in the “Stepper Diagnostics” chapter of the manual,
X axis has no problems, Y axis struggles (I’m losing steps), and Z axis just stalls and locks up.
This test seems pretty aggressive, G0 results in a rather high lineal feed rate. (Stupid high)! Can I change this?
When I run the “axisngc” program (dry, no material/cutting), it seems able, the Y axis growls however on arcs.
It's clear I have a configuration problem here.
If I am unable to get the values needed to calculate an accurate:
“BASE_PERIOD”
“MAX_VELOSITY”
“INPUT_SCALE”
What should I do?
The manual says “No Guessing”, I may not have a choice.
