Forum Header
Mach3 XML and Stepconfig issues.
9 years 6 months ago #91656 by Todd Zuercher
tecno wrote: Changed hal as per your description, erased 2 line and added -2
Still no go, same behavior as before.
Change this line "net estop-out charge-pump.enable iocontrol.0.user-enable-out" to
setp charge-pump.enable 1
To get a charge pump signal of 12.5KHz, you would have to have add the charge pump component to at thread running at 40000ns (or 20000 with the -2). But try the above line change first before we start messing with your thread speeds.
9 years 6 months ago - 9 years 6 months ago #91664 by tecno
Now I can jog both axis, F1/F2 and E-stop works. Need to get proper parameters as it is now way too fast and steppers stall.
Will try to see if I can get the spindle running tomorrow. I only have Index now and only pin 13 free for A-channel. No physical encoder yet on my lathe but have parts to do this but I hope I can get spindle working and have to wait for encoder/threading possibilities.
Thanks for your kind support Todd, much appreciated.
Bengt
Last edit: 9 years 6 months ago by tecno.
9 years 6 months ago #91665 by Todd Zuercher
Just remember when you edit acceleration and feed rates in the ini config file, that those numbers are in units/second. So for max feed rate for example on an inch machine 10 will be 600ipm.
9 years 6 months ago #91668 by tecno
OK, thanks for the info.
9 years 6 months ago #91703 by tecno
Cant find module encoder.update-counters
9 years 6 months ago - 9 years 6 months ago #91705 by Todd Zuercher
Like I said I'm sure I missed some lines for setting up the encoder.
The line:
addf encoder base-thread
should have been:
addf encoder.update-counters base-thread
Last edit: 9 years 6 months ago by Todd Zuercher.
Time to create page: 0.293 seconds
