Gildemeister NEF 480 Retrofit
5 years 4 months ago - 5 years 4 months ago #212212 by anfänger
Wired and tested the encoder
Is there a trick to check the index? The encoder has 2500 increments this might get tricky trying by hand
Edit came by and kicked me in the but and said use the hal-scope not hal show
Last edit: 5 years 4 months ago by anfänger.
5 years 4 months ago #212315 by anfänger
So to protect the new encoder a bit i printed a cover for it and surprisingly its‘ fitting on first try
[img
The cover for the cable hole and the hole it self needed bait of filing but over all it worked well:
[img
5 years 4 months ago #212498 by RotarySMP
You can use HAL show and look at the pin which is the encoder count. Turn a full rev and see if it increments by your expected resolution.
Nice progress. Are those Lichuan drviers? What do you think of them?
Mark
5 years 4 months ago - 5 years 4 months ago #212538 by anfänger
made an error when wiring (cable number 6 and 9 were crossed over) now index and encoders work just fine.
And now my spindle is controlled by LinuxCNC. For proper checking I need to fill in oil but to do that I need to install the new belt pulley for the z-axis. But hopefully this arrived this week. Without oil the clutch to engage the spindle doesn’t work. And to access the Z-Axis servo I need to open the oil tank
For the servo drives I‘cant really tell. They are running and I started to configure them, but I wasn’t able to move them from LinuxCNC yet.
But this is more or less a problem of my lack of skill.
The support is nice and friendly.
Want is a bit of a downside to me is the db40 connector. Soldering this up was a pain, cause I use to thick wires :dry: and the middle line of pins is not a friend of mine. But this ist not the fault of the driver :lol: this is my stupidity. I hope I can tell you more next week. When I can move them. I think there is an error in my starting up procedure
Cheers Patrick
5 years 4 months ago #212590 by anfänger
I can switch them on but they are oscillating :D. I don't get a reading in the DO This I need to check. And find a way to tune everything. So far I think they are doing what they should, I guess.
Now it's reading and remembering what I did six years ago, when I started the last retrofit :D
5 years 4 months ago #212696 by anfänger
I was able to start start and control it a bit.
I am quite happy right now.
Time to create page: 0.347 seconds
