Gildemeister NEF 480 Retrofit
5 years 3 months ago #215034 by tommylight
No idea on the spindle node.
I am in Kosovo.
No worries, i will keep searching for it, in the mean time i might also use a normal chuck, when i get to retrofit it, the Mesa boards i have for it age getting a bit moldy waiting ... :)
5 years 3 months ago #215037 by anfänger
It’s not really near by, good look on the search.
5 years 3 months ago #215170 by anfänger
put the tool mount back on the lathe:
[img
then I took the first cut on the machine:
[img
used the hand wheels to tale the first gut of the face plate
[img
After adjusting the spindle speed the surface finish got better. And I should close the cable ways and make me son wipers.
so here it is ready for drilling the faceplate for the new chuck
[img
looks a lit lost, bu should be enough for most of what's coming next time
[img
The following user(s) said Thank You: RotarySMP, tommylight
5 years 3 months ago #215208 by RotarySMP
It is a cool feeling to make a part on the machine for the first time. You are way ahead of me :)
Mark.
5 years 3 months ago #215238 by anfänger
Yes but I stared before you I guess and don't go into such detail as you.
pus some more sheet metal on the lathe:
[img
[img
[img
and got some left overs one I have no idea where it came from, the other doesn't fit cause of the new servos.
[img
But there is so much left to do. make new wipers, a protection for the panel, route the coolant, close the panel. and finish setting up linuxcnc.
But it "works" now, I can run code, it switches gears, and remembers the one on power down and resets it on start.
the rest is fine tune and make it more convenient to use.
5 years 3 months ago #215803 by anfänger
I might have found a solution to replace the disintegrated way wipers. One was still ok so I used them and it’s holder as a reference to redraw all the missing ones.
And right now the printer is working on a set of new wipers. I use a 98a shore filament. It feels a bit more flexible. But I think this should be ok. I will give them a try soon
[img
[img
[img
Time to create page: 2.905 seconds
