- Thank you received: 167
Thank you for your prompt response.
It looks like I was in error thinking that
<!-- interface-requires gladevcp 0.0 -->
<!-- interface-naming-policy project-wide -->
was a comment. Removing these two lines allowed the hal.ui to load into the glade IDE. It then displays a box but doesn't show the button and LED.
In either case that's not the point. If the Glade IDE requires a 'catalog' then what I'm asking is how to tell the Glade IDE where the 'catalog' is for linux CNC and what it consists of.
I can pull over any folders I need from the Raspberry Pi4 that can run LinuxCNC. And BTW, it throws up the same error when I run Glade on it.
So my question remains the same. The Glade IDE screen designer requires a path to a folder or set of folders in order to be able to load the icons and appropriate HAL connections.
So where are they for the 'simple' example hal.ui. If it can't figure out how to show the items described in the hal.ui then it certainly can't do the AXIS screen.
