RPI4 Raspbian 64 bit & LinuxCNC
4 years 7 months ago #238469 by Elco
Sorry about that, I seem to be at war with the forum software. Tried a few times to attach something, kept saying no file attached.
Here we go again.
File Name: linuxcnc.r...3-27.txt
File Size:5.4 KB
Not my day...
Elco
4 years 7 months ago #238485 by rodw
Can you share your ini file?
Further to What Dewey has said the log indicates some missing ini file sections.
RodW
4 years 7 months ago #238513 by Elco
File Name: cnc03-1.hal
File Size:3.18 KB
File Name: cnc03-1.ini
File Size:5.15 KB
I never made it to a complete .ini file, but I tested many settings (the I86 system that died had an earlier LinuxCNC version. and it got 'converted'. I started from scratch and it took some time to understand the hal file requirements, which I documented first. It was my intention to post one complete working configuration, but after many hours I did not make it that far.
Elco
I Attached is the linuxcnc.report I ran just now on the RPI as well as my .hal and .ini file.
File Size:3.18 KB
File Size:5.15 KB
File Name: linuxcnc.r...3-28.txt
File Size:4.95 KB
4 years 7 months ago #238535 by elovalvo
Meanwhile, there are a number of problems in the .hal file.
In fact, in the instructions hal_pi_gpio.pin-xx-out and hal_pi_gpio.pin-xx-in the parameter xx refers to the physical pin number of the Raspberry and not to the gpio number.
Furthermore, there is no variant -not used for the estop signal In some lines the command hal_pi_gpio.pin-xx-out (xhome and following) is misspelled.
Attached is the correct version of the commands for the .hal file.
The following user(s) said Thank You: Elco
4 years 7 months ago #238543 by Elco
elovalvo,
Thanks a lot for clarifying and fixing the gpio assignments.
Regards,
Elco
4 years 7 months ago - 4 years 7 months ago #238886 by Elco
I am trying to debug at the command line why LinuxCNC does not want to start. I found that when in [EMCMOT] the COMM_TIMEOUT is set to 10 (5 is too short) the following errors disappear:
USRMOT:ERROR: command timeout
emcMotionInit:emcTrayInit failed.
RTAPI then tries to load milltask. However, it fails to find milltask.so in linuxcnc/modules, upon which waitpid times out.
This is with the Linux Raspberry 5.10.74 rt54-V8+ #1 SMP PREEMPT_RT Fri Oct 22 10:15:42 PDT 2021 aarch64 GNU Linux version
LinuxCNC 2.8.2 . The hardware is a RPi 4B 8 GB
All from this file:
Linuxcnc_2.8.2_arm64deb.zip
Elco
Last edit: 4 years 7 months ago by Elco.
Time to create page: 0.189 seconds
