- Thank you received: 62
No, I do not consider Z home to be extended. I consider Z home to be center when controlling 2 heads.Right, I see, you consider home in Z to be fully extended, I think opposite, so I see why you think homing Z first would be wrong.
Yeah you are missing something. We are talking about homing 1 motor that controls 2 heads opposing each other. On a Mill it's pretty much guaranteed that the direction Z will move during homing is the safe direction. That is not the case here.-Why would anyone assume the Z axis home to be down? It is up, always and on every machine i came in contact with.
-Even if using pneumatic Z axis, it should have homing disabled if no air pressure
Or am i missing something?
I have yet to see a machine, any machine that does not home Z first.
I am sure there might be some strange machine that does that, but i can not think of one.
Extruder? I think you completely missed the point.I think I would still home it to the top and then use your work offsets to select which extruder was in use. Any height difference could be accounted for then
And yes home Z first.
