14 Feb 2025 15:49 #321559 by cakeslob
has anyone made qtplasmac work with a NVEM card?
  File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 220, in __init__
    float(self.iniFile.find('AXIS_Z', 'OFFSET_AV_RATIO')) * 60
If anyone had a qtplasmac config for the NVEM, they would have ended our suffering 2 pages ago.
its probably this, i think the THC probably uses external offsets.
add this line and report back
github.com/rodw-au/showstopper/blob/master/my_Plasma.ini#L226
or the next time an error pops up, you can try and trace it out, using all those other plasmac examples I posted before, or by referring to rods config I just listed, otherwise this will be a very long process.
14 Feb 2025 18:05 - 14 Feb 2025 18:11 #321569 by beauxnez
well I'm saved because I see that you are starting to lose patience,
 but I'm not fired because I have the emergency stop that does not unlock but I think I know where it comes from,
 for info I went to debian 12 with linuxcnc 2.9.4 while I was on mint with linuxcnc 2.9.0
Many thanks to you I will post my file and the 2 to 3 things that I know
Last edit: 14 Feb 2025 18:11 by beauxnez.
  • Moderator
  • Moderator
15 Feb 2025 00:18 #321604 by cakeslob
lol its fine, but its going to take a while to get it working 1 error at a time.
17 Feb 2025 01:06 #321790 by Thayloreing
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Good evening, I tried to follow this tutorial, but I couldn't find the stlink bin file, the DAPLink file no longer exists, I couldn't find it anywhere
  • scotta
  • Platinum Member
  • Platinum Member
17 Feb 2025 19:43 #321860 by scotta
This is no longer the recommended method to flash the board. pyOCD has proven to be more reliable.
Use the first part of the video to convert a ST-Link to a CMSIS-DAP probe with the following firmware.
github.com/scottalford75/Remora-NVEM/blo...NVEM-STM32-1.0.0.bin
And then use pyOCD to flash the board as described in this thread.
18 Feb 2025 10:33 #321908 by Thayloreing
Should I just download the bim from pyodc and put it in stlink v2 and after that I will be able to record remora on nven? Could you detail me step by step?
18 Feb 2025 17:57 #321926 by beauxnez
hi no you use a stlink (the green one on the video) to flash a second stlink adapter (the blue one on the video),
then you take the key that you flashed (the blue one) you connect it to a pc and you use PYOCD with the command pyocd flash .\remora-rt1052-3.1.3.bin --target mimxrt1050_quadspi as in the photo
youtube.com/shorts/kLOyWslSZU0?si=C3GMQaH--oAvvTZk
22 Feb 2025 10:28 - 22 Feb 2025 16:51 #322264 by jjdege
hi Scotta
I wanted to compliment you on the work you have done and made available
to the LinuxCNC community.
I am excited about it and I bought an NVEM V5 to try to install the Remora firmware,
but when I opened the case I noticed that the chip is not an STM32F207 but the one in the photo
is it still compatible or did I buy the wrong card?
Thanks if you can give me some advice
P.S. sorry Scotta
I went a bit back with the posts and at 191 there is the answer to my question, thanks,
I'll move on....
Last edit: 22 Feb 2025 16:51 by jjdege.
23 Feb 2025 13:51 #322364 by Thayloreing
Thank you so much for your help, your video helped a lot, I was able to flash on Stlink V2, but how do I install and use pyqcd, I didn't find anything that helped me, I could explain to me, or point someone who has already asked this question to see what He did1
Time to create page: 0.595 seconds
