Gildemeister NEF 480 Retrofit
5 years 3 months ago #215850 by anfänger
So today I put my 3d printed wipers to a test:
[img
[img
[img
​I can't see a difference to the only old wiper in performance. SO now time will tell how they work. When they will be replaced I will make some changes to the lip design, but for now they are working.
While I was on the machine I covered the cables of the cross sled
[img
And there was the issue with the Multifix. the old dowels were sheared of and now replacement has arrived.
but with the dowel the misalignment of the main stud needed to be addressed. After some failed tries to do it by hand. I thought when the machine bended the stud... maybe I jan use it to straighten it:
[img
Now its al properly tightened and true.
[img
the spiral is missing, maybe I print something too
5 years 3 months ago #215855 by anfänger
[img
My spring replacement :side:
This TPU stuff is fun
5 years 3 months ago #216022 by RotarySMP
Those 3D printed way wipers look great. Will be interesting to see how they hold up.
Mark
5 years 3 months ago #216027 by anfänger
Even if they don‘t least as long as the original ones, the cost is less than 1€ in Filament should be no problem to swap them once a year.
If you need some I can print you a set for testing if you send me a 3d filel.
5 years 3 months ago #216587 by anfänger
Closed the console now:
And now I have a switch to tune on the computer. Bund in a 3d printed cover plate. The smaller hole I welded shut.
Whats still on the List is a place for the keyboard and some protection for the console
5 years 2 months ago #216668 by anfänger
Now with a keyboard tray out of some leftovers from the old interior of the control cabinet
[img
And here a video of me try fo figure out If I should find a way to couple the enclosure withe the console.
not sure how to do it, I was thinking about a switchable magnet or so or at least something the easily breaks away when the enclosure gets stuck
Time to create page: 2.063 seconds
