Mesa THCAD-10
3 years 6 months ago #268132 by tommylight
Replied by tommylight on topic Mesa THCAD-10
Make a new config, this one will probably not work.
Use PncConf.
3 years 6 months ago #268133 by phillc54
Replied by phillc54 on topic Mesa THCAD-10
Can you post a backup of the config made from the backup button on the settings tab. Also what resistors you used and the zero an 10 volt frequencies from the THCAD-10 card.
3 years 6 months ago #268137 by tommylight
The hal file is edited and modified, stuff that are normally found on custom.hal are there.
I found out the hard way that QtPlasmaC does not like messing with it's files. :)
3 years 6 months ago #268138 by n2fastcars75
Replied by n2fastcars75 on topic Mesa THCAD-10
I'm using a high voltage 2.4 m ohm on the ground side. I'll have to get a new config made tomorrow after work. 0 volts is 117.6 and 10 volts 941.3. I'll have to get the other stuff from the settings tab tomorrow.
3 years 6 months ago - 3 years 6 months ago #268140 by phillc54
I am not sure why you have:
net plasmac:arc-ok-in <= hm2_7i96s.0.gpio.010.in
Usually this should be an INM Input.
Not sure about this either:
net encoder-count => hm2_7i96s.0.encoder.00.input-b
Are these numbers similar to yours in the Paramaters tab?:
Arc Voltage Offset = 3675.000 Arc Voltage Scale = 0.009712
Apart from the two lines above it seems quite normal.
Last edit: 3 years 6 months ago by phillc54. Reason: Stoopid PITA editor...
3 years 6 months ago #268159 by tommylight
Time to create page: 0.253 seconds
