Here is the second one.
[GUI_OPTIONS]
Exit warning text =
Mode = 0
Autorepeat all = False
Flash error = False
Use keyboard shortcuts = False
Use soft keyboard = False
Show materials = True
Run from line = True
Tool tips = True
Exit warning = True
Preview cone size = 0.5
Preview grid size = 0.0
T view zoom scale = 1.0
Override jog inhibit via Z+ = False
Hide run = False
Hide pause = False
Hide abort = False
DRO position = bottom
Estop type = 0
Custom style = None
[COLOR_OPTIONS]
Foreground = #ffee06
Highlight = #ffee06
LED = #ffee06
Background = #16160e
Background Alt = #36362e
Frames = #ffee06
Estop = #ff0000
Disabled = #b0b0b0
Preview = #000000
[ENABLE_OPTIONS]
THC enable = True
Corner lock enable = True
Void lock enable = False
Use auto volts = True
Ohmic probe enable = False
THC auto = False
[CAMERA_OFFSET]
Camera port = 0
X axis = 0
Y axis = 0
[STATISTICS]
Cut time = 0
Paused time = 0
Probe time = 0
Program run time = 0
Torch on time = 0
Rapid time = 0
Cut length = 0
Pierce count = 0
[PLASMA_PARAMETERS]
Setup Feed Rate = 48.0
Arc Fail Timeout = 3.0
Arc OK High = 250.0
Arc OK Low = 60.0
Arc Maximum Starts = 3
Arc Voltage Offset = 3675.0
Arc Voltage Scale = 0.009712
Velocity Anti Dive Threshold = 90.0
Float Switch Travel = 0.06
Height Per Volt = 0.004
Void Sense Slope = 500
Ohmic Maximum Attempts = 0
Ohmic Probe Offset = 0.0
Pid P Gain = 10.0
Pid D Gain = 0.0
Pid I Gain = 0.0
Probe Feed Rate = 12.0
Probe Start Height = 1.0
Arc Restart Delay = 1.0
Safe Height = 1.0
Scribe Arming Delay = 0.0
Scribe On Delay = 0.0
Skip IHS Distance = 0.0
Spotting Threshold = 1.0
Spotting Time = 0.0
THC Delay = 0.5
THC Sample Counts = 50
THC Sample Threshold = 1.0
THC Threshold = 1.0
[BUTTONS]
1 Name =
1 Code =
2 Name =
2 Code =
3 Name =
3 Code =
4 Name =
4 Code =
5 Name =
5 Code =
6 Name =
6 Code =
7 Name =
7 Code =
8 Name =
8 Code =
9 Name =
9 Code =
10 Name =
10 Code =
11 Name =
11 Code =
12 Name =
12 Code =
13 Name =
13 Code =
14 Name =
14 Code =
15 Name =
15 Code =
16 Name =
16 Code =
17 Name =
17 Code =
18 Name =
18 Code =
19 Name =
19 Code =
20 Name =
20 Code =
[DEFAULT MATERIAL]
Kerf width = 0.04
Pierce height = 0.12
Pierce delay = 0
Puddle jump height = 0
Puddle jump delay = 0
Cut height = 0.04
Cut feed rate = 157.0
Cut amps = 45
Cut volts = 99
Pause at end = 0
Gas pressure = 0
Cut mode = 1
[LASER_OFFSET]
X axis = 0
Y axis = 0
[OFFSET_PROBING]
X axis = 0
Y axis = 0
Delay = 0
[POWERMAX]
Port =
