Mesa THCAD-10
3 years 6 months ago #268161 by phillc54
Replied by phillc54 on topic Mesa THCAD-10
Crikey, I must be getting too old for this. I went through the hal file several times and missed that one. image missing /media/kunena/emoticons/sad.png
3 years 6 months ago #268206 by n2fastcars75
Replied by n2fastcars75 on topic Mesa THCAD-10
File Name: my_plasma2.ini
File Size:5.19 KB
File Name: my_plasma2.hal
File Size:11.09 KB
ok i created a new config with pncconfig wizard. My arc voltage is still a negitive number -34. I will need to do some work on ini for limits and home stuff. The wizard always gets me confused when setting up limit and home switches. I do better just changing them in the ini. Didnt see anything about encoder scale in the hal this time either. I picked mode 1 on qtplasmac gui screen page on wizard. Im pretty sure i did as well on the first config. I have thcad-10 picked F jumper 32 and it moved to that on the board. 0v 117.6 full scale 10v 941.3 and divider set to 24. Not sure 24 is right for divider? Theres a realtime page in wizard is this where you set scale? Add hal components? Im guessing this is what i dont have?
3 years 6 months ago #268208 by n2fastcars75
I also picked encoder for arc voltage on number 0 in TB1/TB2 tab in wizard. I had made changes to the output and input in first hal i created. Just something i thought wasn't I needed to change because [HMOT] (CARD0) looked funny. I have used a 7i76 and thats how it uses its input and outputs. hm2_7i76.0. Anyway that why that was changed.
3 years 6 months ago #268213 by phillc54
You should enter the divider ratio if your CPC port has a divider. If you use resistors then you should enter the resistor value.
I thought you used a 2.4M resistor, if so then the values on the Parameters tb should match those in my earlier post.
INI and HAL files don't give enough information, use the back up and post that.
3 years 6 months ago #268217 by n2fastcars75
Well crap can get you a picture of the parameters page but voltage scale is .009324 and voltage offset is 3675.  Not sure how the back up works. I click on it and it make a text file but there's only like 3 lines of text. Do I just copy and paste that into hal? It just states machine log 23-04-03_20-47-31.txt
3 years 6 months ago #268219 by n2fastcars75
Ok I did find the back up file. What do I need to do with it? It does show voltage scale and offset. Along with a bunch of other stuff.
Time to create page: 0.082 seconds
