- Thank you received: 5334
I was only getting .112 of a volt at my encoder a input pins on the 7i96s board while cutting with the plasma.
Sorry for being blunt, but stop, go read the manuals for both cards (not everything, just the 3 to 5 pages) then go back at it.I was thinking i would need to be inputting 100 to 200 volts for the thcad-10 to output the 0-10 volts?
You should have stopped there and check everything, that should read 0 when THCAD is wired and set up properly regarding scaling and offset.I was getting a -36 reading on the axis gui all the time without any change after firing the torch .....
The green one should blink when THACD is powered.I looked though the manuals and did notice that the thcad-10 board should have a cr2 yellow and cr5 green led working on the board. Im only getting the one yellow led.
Yes it is correct, and no do not move the jumpers.Another thing i did see as well is that the 7i96s has jumpers for the encoders on it. Im thinking it needs to be set for single-ended (TTL)? There's a commet about only needing to use a + wire to the encoder? Im using fout+ to encoder+ and fout- to encoder- does this sound right?
That does not seem OK on many levels, even with the torch on you should get under 10V on THACD inputs, so make sure the shop, plasma source, machine, computer, ALL have proper grounding, This is not negotiable on plasma machines, no ground usually means dead parts.I also have 65 or so volts coming into the thcad-10 board with the 2.5m ohm resistor on the pin that is connected to the ground lead. Does this sound right?
Does not matter much, i prefer 2, but i mostly use old plasma sources so it makes it safer in case a wire is nicked on the way to THCAD.I see others say you need 1m ohm on each pin.
