qt_dragon_hd - manual tool change and remap
3 years 5 months ago #272072 by cmorley
you will need to invert the signal now.
probe-input must be normally false - true when tripped.
The following user(s) said Thank You: grey_goat
3 years 5 months ago #272130 by grey_goat
I inverted the signal. Now when I trigger the toolsetter after completing a tool change I immediately get. "Probe is already tripped when starting G38.2 or G38.3 move"
3 years 5 months ago #272135 by cmorley
hmm can you confirm again that motion.probe-in is false when the probe is not tripped?
3 years 5 months ago - 3 years 5 months ago #272137 by grey_goat
Can confirm.
My understanding is that the tool was supposed to touch the tool setter, back up, and then touch it again slowly. At the moment a single touch triggers, "the probe is already tripped," when pressed for the first time.
Last edit: 3 years 5 months ago by grey_goat.
3 years 5 months ago #272147 by cmorley
What speeds to you have set for searching/probing?
3 years 5 months ago #272177 by grey_goat
Search velocity is 40mm/min and probe velocity is 10mm/min
Time to create page: 0.312 seconds
